Addition of Rotation correction to SA Turbulence Model
Old   May 7, 2012, 02:30
Default Addition of Rotation correction to SA Turbulence Model
Kalyan
kalyangoparaju is on a distinguished road
Guys,
I am trying to simulate wing tip vortices by modified the existing SA model by adding a rotational correction to it. This was proposed by Dacles and Mariani. It is the SA-R model in the following.
http://turbmodels.larc.nasa.gov/spalart.html
According to the above link, the only major difference is the way in which S_tilda is calculated. Finally, S_tilda will have to look like
S_tilda=Omega+Crot*min(0,S-Omega)+nu_tilda*fv2/(k*d)^2
I tried to code this into openfoam the following way.
const volScalarField omega(::sqrt(2.0)*(mag(skew(fvc::grad(U_)))));
const volScalarField S(::sqrt(2.0)*(mag(symm(fvc::grad(U_)))));
const volScalarField Stilda
omega + scalar(2) * min(omega-omega,S-omega)
+ fv2(chi, fv1)*nuTilda_/sqr(kappa_*d_)
The only reason I have omega-omega is so that I don't have to define 0 as a dimentionedScalar. can someone tell me if I am doing this right.
I've tested this version and the results seem to be wrong. The results are right with the actual ( unmodified )implementation of SA model .
Kalyan
kalyangoparaju is offline   Reply With Quote
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
SimpleFoam case with SpalartAllmaras turbulence model implemented nedved OpenFOAM Running, Solving & CFD 2 November 30, 2014 22:43
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
Turbulence model for CFX moving mesh songxguan CFX 7 June 28, 2009 21:05
