interDyMFOAM with moving mesh
Old   May 23, 2012, 11:17
Default interDyMFOAM with moving mesh
bojiezhang
bojiezhang is on a distinguished road
hello every former:
I use interDyMFOAM with moving mesh(displacementLaplacian), and I use the pointDisplacement to control the boundary motion.
when I set a small displacement for one boundary, at the first time step, all is ok and the internal mesh move formally.
but at the second time step, I find the mesh on the boundary distorted, and the internal mesh certainly also distorted. At the same time, the courant number become very large and the caculation terminated.
I feel confused if the displacementLaplacian is credible, for it can not be applied for such a small displacement.
Hope someone could tell me if I did something wrong.
Thank you!
bojiezhang
bojiezhang is offline   Reply With Quote
Old   June 6, 2013, 23:13
kingleli
kingle is on a distinguished road
I've been investigating scour around objects. I know that when the amplitude of the boundary movement is big enough, the mesh may be highly distorted and make the computation not easy to converge, this is the limitation of mesh deformation approach. I advice you to try dynamic mesh approach, mesh cells can be split or merged when necessary, but this method is difficult.
kingle is offline   Reply With Quote
Old   October 2, 2013, 10:48
Su Xiaohui
sxhdhi is on a distinguished road
Send a message via Skype™ to sxhdhi
Dear Bojie
I would like to know whether you have solved your small displacement moving BC problem or not.
I also meet the same problem here.
sxhdhi is offline   Reply With Quote
Old   October 5, 2013, 08:13
Retired Super Moderator
Bruno Santos
Greetings to all!
Without an example, there isn't much anyone can do to help you, as explained here: How to give enough info to get help
Nonetheless, have a look into this post for ideas for a possible solution: http://www.cfd-online.com/Forums/ope...tml#post398703 post #12
Best regards,
Bruno
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
Dynamic Mesh moving interface help akash.iitb FLUENT 0 August 23, 2010 23:53
Resisting torque on a moving mesh floooo OpenFOAM 3 March 29, 2010 20:18
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
