CyclicAMI: Problems with pressure field
Like Tree1Likes
  • 1 Post By maHein
Old   September 20, 2012, 00:10
Default CyclicAMI: Problems with pressure field
Thomas S
Thoma is on a distinguished road
I am working with cyclicAMI boundary condition. But on the edges to other bcs I am getting weird results for the pressure field.
I have attached a screenshot to make my problem clear.
And that is the content of .../0/p:
PHP Code:
/*--------------------------------*- C++ -*----------------------------------*| =========                 |                                                 |
| \      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
|  \    /   O peration     | Version:  2.0.1                                 |
|   \  /    A nd           | Web:      www.OpenFOAM.com                      |
|    \/     M anipulation  |                                                 |
FoamFile
version     2.0;
format      ascii;
    class
volScalarField;
object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 100000;
boundaryField
inlet
type            zeroGradient;
outlet
type            fixedValue
value           uniform 100000;
wall
type            zeroGradient;
vane
type            zeroGradient;
side1
type            cyclicAMI;
side2
type            cyclicAMI;
inject
type            zeroGradient;
sym
type        slip;
hole
type            zeroGradient;
vane_inflow
type            zeroGradient;
Does anybody know what is wrong in my simulation? Thank you very much for your help!!
Regards, Thomas
Thoma is offline   Reply With Quote
Old   September 21, 2012, 09:20
Hugh Ingham
martyn88 is on a distinguished road
I have a similar problem with my pressure field when I use cyclicAMI. Can I ask why you didn't just use cyclic conditions?
martyn88 is offline   Reply With Quote
Old   September 23, 2012, 21:58
Thomas S
Hey,
the cyclic Boundary condition never worked for me in this model. I had always mismatching problems with the mesh. (I am using Salome 6.3 for the mesh generation). But with AMI it seemed to work. Though it looks like that OpenFoam sets some default boundary conditions on the edges.
Does anyone knows how to solve this issue?
Old   November 14, 2012, 03:41
Default Similar issue
javier_b is on a distinguished road
Hey Thomas,
Did you manage to solve your problem? I am having a very similar issue.
Javier
javier_b is offline   Reply With Quote
Old   January 10, 2013, 14:15
Default cyclicAMI pressure boundary
Shantan
shantan is on a distinguished road
I have also the same problem! does somebody have any idea or could comment on it, if it would be a bug?!
shantan is offline   Reply With Quote
Old   January 10, 2013, 14:34
Thomas S
Hey,
no sorry, I never solved the problem. I just neglected it in the end....
But let me know if you find a solution!
Old   January 11, 2013, 17:17
maHein is on a distinguished road
I successfully used cyclicAMIs for turbomachinery flow simulation. I don't know, if you are using MRF. However, I experienced promblems when not correctly defining the "nonRotatingPatches" in the MRFDict.
Chandsome likes this.
maHein is offline   Reply With Quote
Old   January 24, 2013, 05:41
Dongyue Li
sharonyue is on a distinguished road
I am having a very similar issue too.....
sharonyue is offline   Reply With Quote
Old   February 21, 2013, 05:51
Default cyclicAMI for nonConformal meshes
prasant
prasant is on a distinguished road
Hello All,
Did anybody face an issue while using cyclicAMI on nonConformal Meshes?
My case is an impeller with volute also. Impeller is having pure Hexhedral and volute is having tetrahedral grid. I am giving cyclicAMI boundary condition for those interfaces.
I am giving mass flow at outlet and totalPressure at inlet.
By using the above settings, Mass is not balancing. The issue is, data is not transferring between these two interfaces. because of cyclicAMI.
And also Temperature values are not coming correct at outlet. Actually Ggi (OpenFOAM-1.6-Extd) is working fine with these settings. but here, Compressible solver with MRF is not available in this version. I modified the code. But there are some other issues.
So, Finally I came back to OpenFOAM current version (i.e) OF-2.1.1.
Please help me, If anybody success with cyclicAMI boundary conditon.
Regards
Prasant.
prasant is offline   Reply With Quote
Old   February 21, 2013, 11:04
Can you post your boundary file and the weithing factors for your case?
Old   February 22, 2013, 03:51
prasant
I am attaching my boundary file and weithing factors here:
| \\ / O peration | Version: 2.1.1 |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class polyBoundaryMesh;
location "constant/polyMesh";
object boundary;
8
r1-default
type wall;
nFaces 4176;
startFace 410703;
r1-hub
type wall;
nFaces 4914;
startFace 414879;
r1-inlet
type patch;
nFaces 864;
startFace 419793;
r1-shroud
type wall;
nFaces 4914;
startFace 420657;
s1-to-r1-side-2
type cyclicAMI;
nFaces 1008;
startFace 425571;
matchTolerance 0.0001;
neighbourPatch s1-to-r1-side-1;
transform noOrdering;
s1-default
type wall;
nFaces 16418;
startFace 426579;
s1-outlet
type patch;
nFaces 360;
startFace 442997;
s1-to-r1-side-1
type cyclicAMI;
nFaces 1926;
startFace 443357;
neighbourPatch s1-to-r1-side-2;
and weithing factors are
Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
AMI: Creating addressing and weights between 1008 source faces and 1926 target faces
AMI: Patch source weights min/max/average = 0.96403269, 1.0072789, 0.99952117
AMI: Patch target weights min/max/average = 0.83982674, 1.0035554, 0.99658895
Please view it and help me regarding this.
Thanks & Regards
Prasant
Old   April 28, 2014, 09:25
Default No solution
  #12
Víctor Mendoza García
vitoco is on a distinguished road
Hey Foamers...
Exactly the same here... and not solution. The edges take the pressure (atmospherical in my cases) and stays in a fixed value during all the simulation. This creates a non realistic field. Best regards,
Victor Mendoza
vitoco is offline   Reply With Quote
Old   May 9, 2014, 10:05
Ros
Rostyslav Lyulinetskyy
Ros is on a distinguished road
I am having the same problem with the pressure field. I already tested it on a straight channel with cyclicAMI and cyclic BC's. Only with the cyclic BC the pressure field is correctly calculated.
My geometry is similar to the geometry posted by Thomas. So in my case only cyclicAMI can work.
Does anyone have an idea what to do?
Thanks
Ros is offline   Reply With Quote
Old   June 28, 2014, 08:34
M. C.
student666 is on a distinguished road
any news about cyclic AMI Problem?
student666 is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Translate the pressure field on a cylinder side to a plane rockzh CFX 7 November 23, 2011 00:50
Help creating a field function to create a sine pressure wave Pleb STAR-CCM+ 2 February 17, 2011 12:16
Pressure more accurate than velocity field? jrg FLUENT 1 October 30, 2007 11:11
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
