BCs for k and epsilon at walls with y+=1
Like Tree1Likes
  • 1 Post By sylvester
Old   October 15, 2012, 15:18
Default BCs for k and epsilon at walls with y+=1
Vangelis Skaperdas
vangelis is on a distinguished road
Hello everybody,
I would like to know the following for OpenFOAM 2.1.1:
when setting up a turbulent flow case with a mesh that leads to y+ values of 1 I do not need to use wall functions.
What is the correct BC for k and epsilon in such a case
Are they fixedValue=0 or
zeroGradient?
Similar question for k-omega models also.
I have found this post
http://www.cfd-online.com/Forums/ope...m-1-5-dev.html
but it refers to previous OF releases
Thanks!
vangelis is offline   Reply With Quote
Old   October 16, 2012, 03:22
Roland
sylvester is on a distinguished road
Hi Vangelis,
To my understanding you would (theoretically) set both at fixedValue = 0, as there is no turbulence possible in the viscous sublayer. And as there is no turbulence, you also can't have dissipation of turbulence.
I say theoretical because actually setting the BC's to 0 would result in a division by zero in the OpenFOAM implementation. In practice you would therefore set them to a very small value, for example fixedValue = 1e-12.
Best regards,
Sylvester
saeed jamshidi likes this.
sylvester is offline   Reply With Quote
Old   October 16, 2012, 03:51
Vangelis Skaperdas
Hi Sylvester!
Thank you very much for your reply.
Best regards
Vangelis
Old   October 16, 2012, 08:57
Vangelis Skaperdas
Hi Sylvester
I forgot to also specify that
nut should also be set to fixedValue=0
like k, right?
Vangelis
Old   October 16, 2012, 09:14
Roland
Hi Vangelis,
Or use nutLowReWallFunction, which makes the patch accessible from yPlusRAS.
From nutLowReWallFunctionFvPatchScalarField.H:
Description
Boundary condition for turbulent (kinematic) viscosity when for use with
low Reynolds number models.
Sets nut to zero, and provides an access function to calculate y+.
regards,
Sylvester
ps. Can we perhaps expect improved OpenFOAM pre-processing in ANSA v13.3?
Old   October 16, 2012, 10:25
Vangelis Skaperdas
We are trying to do this.
And in this sense thank you for your help!
so you mean that it is better to use
so that afterwards I can get values for y+?
Otherwise it would be the same as setting fixedValue=0 for nut at walls?
Old   October 16, 2012, 10:52
Roland
Hi Vangelis,
Yes, from what I can gather it is better to use the nutLowReWallFunction. But I haven't done much work with low Re turbulence models, so I may be wrong here.
Best regards,
Sylvester
Old   October 16, 2012, 11:45
Vangelis Skaperdas
Thanks again Sylvester!
Epsilon boundary condition for walls in LamBremhorst LowRe model maruthamuthu_venkatraman OpenFOAM 1 April 21, 2019 06:25
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 08:30
How to set up BCs for k epsilon model Julian K. OpenFOAM Pre-Processing 44 October 26, 2015 09:23
Dealing with BC's in OF 1.6 vkrastev OpenFOAM Running, Solving & CFD 5 September 4, 2012 11:58
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 20:21
