Different results in parallel/serial mode
Old   October 22, 2012, 04:23
Default Different results in parallel/serial mode
kpax is on a distinguished road
Hello FOAMers,
a simple question:
i recently discovered that when I run a case in parallel and in serial mode, the results are not exactly the same. Why is that?
How can I avoid these errors in parallel mode (I assume the serial mode can be seen as a reference?), and how do they depend on the way i decompose the geometry?
I couldn't find anything about this topic in the forum, but if you know other threads that answer my question, links to these would also be appreciated.
Thanks in advance!
kpax is offline   Reply With Quote
Old   October 22, 2012, 06:22
akidess's Avatar
Anton Kidess
Maybe this helps: http://www.openfoam.org/mantisbt/view.php?id=223
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 10 May 13, 2018 18:28
Wave Tank kester OpenFOAM Running, Solving & CFD 88 November 28, 2012 14:57
wind tunnel results vs fluent pixie Main CFD Forum 1 August 20, 2009 08:02
Velocity spots in openFoam results Valle OpenFOAM Running, Solving & CFD 4 August 19, 2009 05:53
How to plot a function over a time period? Cirion0000 CFX 4 July 18, 2009 12:48
