Non-physical alpha1 with interFoam and high contact angles
Like Tree1Likes
  • 1 Post By michielm
Old   November 1, 2012, 23:37
Default Non-physical alpha1 with interFoam and high contact angles
steph79 is on a distinguished road
Hello all,
I'm using OpenFOAM 2.1.1 (interFoam solver) to model water droplet impacts on superhydrophobic surfaces with very high constantAlphaContactAngle - 163 degrees. In short, it's an extension of the dam break tutorial where there's an initialised droplet of water within the domain which, after a period of time, will impact on a superhydrophobic surface. Here are my BC's;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    substrate
        type            fixedValue;
        value           uniform (0 0 0);
    atmosphere
        type            pressureInletOutletVelocity;
    defaultFaces
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p_rgh;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    substrate
        type            totalPressure;  // zeroGradient; has also been attempted
        p0              uniform 0;
        U               U;
        phi             phi;
        rho             rho;
        psi             none;
        gamma           1;
        value           uniform 0;
    atmosphere
        type            totalPressure;
        p0              uniform 0;
        U               U;
        phi             phi;
        rho             rho;
        psi             none;
        gamma           1;
        value           uniform 0;
    defaultFaces
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    object      alpha;
dimensions      [0 0 0 0 0 0 0];
boundaryField
    substrate
        type            constantAlphaContactAngle;
        gradient        uniform 0;
        limit           none;
        theta0          163;
        value           uniform 0;
    atmosphere
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    defaultFaces
        type            empty;
Now I've tried this for 90 & 100 degrees and it works fine, but with 163 degrees alpha1 becomes strongly non-physical and this appears to be the case irrespective of Courant number conservativeness, the number of alpha sub cycles and (in the following case) very strict tolerance criteria. See below;
Courant Number mean: 0.00770252 max: 0.487324
Interface Courant Number mean: 0.000653673 max: 0.474258
deltaT = 1.13562e-05
Time = 0.0803864
MULES: Solving for alpha1
Phase-1 volume fraction = 0.00347786  Min(alpha1) = -0.353626  Max(alpha1) = 1.00404
Phase-1 volume fraction = 0.00347586  Min(alpha1) = -0.350839  Max(alpha1) = 1.00402
Phase-1 volume fraction = 0.00347386  Min(alpha1) = -0.347173  Max(alpha1) = 1.00401
Phase-1 volume fraction = 0.00347187  Min(alpha1) = -0.345021  Max(alpha1) = 1.00399
Phase-1 volume fraction = 0.00346987  Min(alpha1) = -0.346423  Max(alpha1) = 1.00398
DICPCG:  Solving for p_rgh, Initial residual = 0.013328, Final residual = 9.31482e-13, No Iterations 257
time step continuity errors : sum local = 1.35985e-15, global = 4.94506e-17, cumulative = -7.33426e-11
DICPCG:  Solving for p_rgh, Initial residual = 0.0013377, Final residual = 9.42321e-13, No Iterations 235
time step continuity errors : sum local = 1.38612e-15, global = -2.03524e-17, cumulative = -7.33426e-11
DICPCG:  Solving for p_rgh, Initial residual = 0.00022603, Final residual = 9.38786e-10, No Iterations 164
time step continuity errors : sum local = 1.38035e-12, global = 3.02764e-14, cumulative = -7.33123e-11
ExecutionTime = 926.66 s  ClockTime = 1033 s
There are no issues when the droplet is free-falling, only during surface contact and thereafter.
Could anyone advise me on what course of action to take? Am I misplaced in thinking that interFoam is suitable for this problem, and if so, is there a better choice of solver for this case? Incidentally, I have tried more diffusive upwind divergence schemes without success either, below are my present schemes;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    div(rho*phi,U)  Gauss limitedLinearV 1;
    div(phi,alpha)  Gauss vanLeer;
    div(phirb,alpha) Gauss interfaceCompression;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p_rgh;
    pcorr;
    alpha1;
Any help would be greatly appreciated. Thanks.
steph79 is offline   Reply With Quote
Old   November 2, 2012, 03:28
akidess's Avatar
Anton Kidess
Try this http://www.cfd-online.com/Forums/ope...tml#post346690
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   November 2, 2012, 05:35
Duong A. Hoang
duongquaphim is on a distinguished road
Send a message via Yahoo to duongquaphim
I was noticed some issues related to contact angle boundary condition in openfoam (look at http://www.cfd-online.com/Forums/ope...interfoam.html).
The contact angle boundary conditions which I will use for alpha1 and p are:
substrate
limit gradient;
theta0 163;
value uniform 0;
and
substrate
type fixedFluxPressure;
adjoint no;
And they work fine for me for a wide range of contact angle.
Duong
duongquaphim is offline   Reply With Quote
Old   November 3, 2012, 03:12
Thanks for your suggestions. They have shown some promise so far but I will try to get back with firmer conclusions in the near future.
On another note, when saving long animations in paraFoam, the software appears to suffer from a memory leak and crashes when I run out of RAM and swap space respectively. Could anyone point to a solution regarding this additional problem? I can work my way around it manually, in several ways, but that's a last resort. I've seen this issue discussed elsewhere but I haven't come across the solution.
Thanks.
Old   November 3, 2012, 06:44
Michiel
michielm is on a distinguished road
I have the same experience as Duong: use the BC's he is suggesting and your problem should go away.
On a side note:
I strongly doubt that the constantAlphaContactAngle is the correct BC to be using at all for droplet impact. The main problem is that the velocity dependence of the contact angle will dramatically change the spreading behaviour (see e.g. [1]), which is typically an important aspect of the droplet impact.
You could look into the dynamicAlphaContactAngle or even progam your own dynamic model, like the Cox-Voinov model.
Cheers,
Michiel
[1] Carlson et al. Phys. Fluids 21, 121701 (2009) - http://link.aip.org/link/doi/10.1063/1.3275853
michielm is offline   Reply With Quote
Old   November 3, 2012, 23:32
Thanks everybody, I now have some stable results to work with and improve upon, having implemented the boundary conditions first suggested by duongquaphim.
@michielm I have used dynamicAlphaContactAngle previously but that was only from the point of view of attempting to overcome the stability and non-physical issues I outlined earlier. That said, however, I think it's something I am more than likely to return to. Incidentally, does anyone have a heads-up on a viable way to include porous effects on the substrate?
Thanks again.
Old   November 6, 2012, 02:54
Michiel
I think this depends a lot on the difference in length scales of your porous structure and your droplet. If e.g. the pores are 200 micron and your droplet is 2000 micron then you might consider to really mesh the pores.
If however the pores are closer to 20 micron then you need some kind of subgrid model/an appropriate BC for it. I know that OF has some libraries/models to work with porous zones so you could look into that. A useful starting point might be this: http://www.tfd.chalmers.se/~hani/kur...ukurReport.pdf
luoyang likes this.
Old   November 6, 2012, 04:17
Thanks, yes I have meshed the pores previously, but not at a resolution that would allow satellite droplets to form.
Previously (in ANSYS Fluent) I just bundled the slot gaps (pores) with my 'atmosphere' BC, I presume that's the logical way to go. I can also break my substrate stems and tips into two patches, with different contact angles respectively.
Artificial high velocities at the interface using interFoam Arnoldinho OpenFOAM Running, Solving & CFD 37 August 30, 2018 06:25
InterFoam Artificially High Velocities andersson.j OpenFOAM Running, Solving & CFD 0 February 8, 2011 10:43
High depression at low alpha inlet (interFoam) santiagomarquezd OpenFOAM Running, Solving & CFD 0 June 1, 2010 17:18
interFoam: strange pressure with high fluid viscosity? ckroener OpenFOAM 3 April 7, 2010 12:51
