multiphaseEulerFoam loosing fluid with zeroGradient for p on walls???
Old   November 28, 2012, 06:33
Default multiphaseEulerFoam loosing fluid with zeroGradient for p on walls???
Petr Furmanek
petr.f. is on a distinguished road
Dear fellow foamers,
I've run into another strange problem with multiphaseEulerFoam (mpEF). In order to perform scalability tests with mpEF, I've prepared a simple 3d dam break case (only 2 phases - air and water). I've used standard boundary conditions and solver settings taken from tutorial files (see below). When I use the zeroGradient BC for pressure on solid walls all the water somehow leaks through the walls (with no effect on Courant number!). fixedFluxPressure works just well... Any idea where this behaviour comes from?
0.org/alphaair
boundaryField
walls
type zeroGradient;
atmosphere
type inletOutlet;
phi phiair;
inletValue uniform 1;
value uniform 1;
alphawater is almost the same, only on atmosphere the inletValue and value are uniform 0
0.org/p
boundaryField
walls
type zeroGradient;
atmosphere
type totalPressure;
p0 uniform 0;
U Uair;
phi phiair;
rho rho;
psi none;
gamma 1;
value uniform 0;
0.0rg/Uair
boundaryField
walls
type fixedValue;
value uniform (0 0 0);
atmosphere
type fluxCorrectedVelocity;
... again, Uwater is the same
system/fvSolution
solvers
p
solver GAMG;
tolerance 1e-7;
relTol 0.05;
smoother DIC;//GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
nFinestSweeps 2;
cacheAgglomeration on;
nCellsInCoarsestLevel 10;
agglomerator faceAreaPair;
mergeLevels 1;
pFinal
solver PCG;
preconditioner
preconditioner GAMG;
tolerance 1e-7;
relTol 0;
nVcycles 2;
nPreSweeps 0;
nPostSweeps 2;
nFinestSweeps 2;
mergeLevels 1;
tolerance 1e-7;
relTol 0;
maxIter 20;
pcorr
$pFinal;
tolerance 1e-5;
relTol 0;
U
solver smoothSolver;
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
UFinal
$U;
tolerance 1e-7;
relTol 0;
PIMPLE
// nOuterCorrectors 1;
nCorrectors 3;
nNonOrthogonalCorrectors 0;
nAlphaSubCycles 3;
relaxationFactors
"U.*" 1;
p 1;
As for fvSchemes, I use vanLeer and limitedLinear as in damBreak tutorial.
Thanks, Petr.
petr.f. is offline   Reply With Quote
Fluid Structure Interaction Apollo Main CFD Forum 5 July 4, 2011 16:15
What is the total energy for incompressible fluid? Harry Dong Main CFD Forum 12 February 4, 2006 00:55
Intl Conf Computational Methods in Fluid Power Jacek Stecki Main CFD Forum 0 November 10, 2002 05:49
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
