May 5, 2013, 23:27 |
decomposePar pointfield
xinguang cui
Rep Power: 17 |
Dear All foamers:
I have met a problem when I use decomposePar to decompose the field which has a dynamic boundary. The boundary motion is described with a pointfield. The problem appears when the decompose plane crosses the dynamic boundary. Otherwise, it seems Ok. In additiion, I have found that the problem has been encountered by other users, but it seems that there are nobody to solve it. My error information as follows: [6] --> FOAM FATAL IO ERROR: [6] size 6977 is not equal to the given value of 933 [2] file: /gpfs/home/xgcui/OpenFOAM/xgcui-2.0.0/run/test1/flow3d-movingmesh-f-3/processor2/0/pointMotionU::boundaryField::WALL1 from line 26 to line 7013. [2] [2] From function Field<Type>::Field(const word& keyword, const dictionary&, const label) [2] in file /usr/local/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/Field.C at line 236. [2] FOAM parallel run exiting [2] [6] [6] file: /gpfs/home/xgcui/OpenFOAM/xgcui-2.0.0/run/test1/flow3d-movingmesh-f-3/processor6/0/pointMotionU::boundaryField::WALL1 from line 26 to line 7013. [6] [6] From function Field<Type>::Field(const word& keyword, const dictionary&, const label) [6] in file /usr/local/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/Field.C at line 236. [6] FOAM parallel run exiting [6] [0] [0] --> FOAM FATAL IO ERROR: [0] size 6977 is not equal to the given value of 944 [0] [0] file: /gpfs/home/xgcui/OpenFOAM/xgcui-2.0.0/run/test1/flow3d-movingmesh-f-3/processor0/0/pointMotionU::boundaryField::WALL1 from line 26 to line 7013. [0] [0] From function Field<Type>::Field(const word& keyword, const dictionary&, const label) [0] in file /usr/local/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/Field.C at line 236. [0] FOAM parallel run exiting [0] [4] [4] --> FOAM FATAL IO ERROR: [4] size 6977 is not equal to the given value of 866 [4] [4] file: /gpfs/home/xgcui/OpenFOAM/xgcui-2.0.0/run/test1/flow3d-movingmesh-f-3/processor4/0/pointMotionU::boundaryField::WALL1 from line 26 to line 7013. [4] [4] From function Field<Type>::Field(const word& keyword, const dictionary&, const label) [4] in file /usr/local/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/Field.C at line 236. [4] FOAM parallel run exiting [4] [7] [7] [3] [3] [3] --> FOAM FATAL IO ERROR: [3] size 6977 is not equal to the given value of 876 [3] [3] [7] --> FOAM FATAL IO ERROR: [7] size 6977 is not equal to the given value of 1025 [7] file: /gpfs/home/xgcui/OpenFOAM/xgcui-2.0.0/run/test1/flow3d-movingmesh-f-3/processor3/0/pointMotionU::boundaryField::WALL1 from line 26 to line 7013. [3] [3] From function Field<Type>::Field(const word& keyword, const dictionary&, const label) [3] in file /usr/local/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/Field.C at line 236[7] file: /gpfs/home/xgcui/OpenFOAM/xgcui-2.0.0/run/test1/flow3d-movingmesh-f-3/processor7/0/pointMotionU::boundaryField::WALL1 from line 26 to line 7013. [7] [7] From function Field<Type>::Field(const word& keyword, const dictionary&, const label) [7] in file /usr/local/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/Field.C. [3] FOAM parallel run exiting [3] at line 236. [7] FOAM parallel run exiting [7] [1] [1] [1] --> FOAM FATAL IO ERROR: [1] size 6977 is not equal to the given value of 840 [1] [1] file: /gpfs/home/xgcui/OpenFOAM/xgcui-2.0.0/run/test1/flow3d-movingmesh-f-3/processor1/0/pointMotionU::boundaryField::WALL1 from line 26 to line 7013. [1] [1] From function Field<Type>::Field(const word& keyword, const dictionary&, const label) [1] in file /usr/local/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/Field.C at line 236. [1] FOAM parallel run exiting [1] [5] [5] [5] --> FOAM FATAL IO ERROR: [5] size 6977 is not equal to the given value of 808 [5] [5] file: /gpfs/home/xgcui/OpenFOAM/xgcui-2.0.0/run/test1/flow3d-movingmesh-f-3/processor5/0/pointMotionU::boundaryField::WALL1 from line 26 to line 7013. [5] [5] From function Field<Type>::Field(const word& keyword, const dictionary&, const label) [5] in file /usr/local/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/Field.C at line 236. [5] FOAM parallel run exiting Does anybody have any ideas on it? Would you please give me some hints on it? Best wishes! Last edited by flying; May 5, 2013 at 23:28. Reason: add content |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
