DieselEngineFoam heat release
Old   January 16, 2013, 14:10
Default DieselEngineFoam heat release
ris
ri
ris is on a distinguished road
I am attempting to extract dQ from my simulation using simplefunctionobjects and swak4foam. I successfully implemented the following in OF2.1.x:
functions
volumeAverage
type volumeAverage;
functionObjectLibs
"libsimpleFunctionObjects.so"
verbose true;
fields
T
dQ
C7H16
factor 1;
Unfortunately due to other problems I am now using OF1.7.1 . When I add this function to the controlDict in OF1.7.1 the Temperature and C7H16 fields are successfully extracted, however I recieve the following error for dQ.
FOAM Warning :
From function probes::read()
in file volume/volumeFieldFunctionObject/volumeFieldFunctionObject.C at line 91
Unknown field dQ when reading dictionary "::volumeAverage"
Can only probe registered volScalar, volVector, volSphericalTensor, volSymmTensor and volTensor fields
Which from what I can understand, means that it cannot read/recognize dQ. Has anyone experienced this before? and does anyone know another method of extracting dQ. I have tried execFlowfuntionobjects but my thermomodel is not supported.
Many Thanks,
ris
ris is offline   Reply With Quote
Old   January 18, 2013, 12:01
ris
ri
I have another question regarding extracting the liquid penetration length from the data set during runtime. Looking in spraycloud.H , I can see there is a liquidPenetration function however I am not too familiar with c++ and have trouble in trying to output this value. Please could some point me in the direction of outputting this value to a log file during runtime or a similar output to what is present in OF2.1.x.
Many Thanks,
ris.
Old   January 18, 2013, 12:34
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
dQ is not a registered field as it is only output as needed from the chemistry model (chemistry.dQ()). You would need to create a field registered with the object (say Dq) and update is every iteration with the chemistry (Dq = chemsitry.dQ()).
Have a look at the createFields.H for reactingParcelFoam (which is also used with sprayFoam) to see how to create a registered field.
As for penetration length, have a look at this post:
http://www.cfd-online.com/Forums/ope...netration.html
Its slightly different in 2.1.x, but there are still member functions for penetration that you could use (search through the code documentation here: http://www.openfoam.org/docs/cpp/). This would require you to modify the code, and I would recommend creating a new solver so as not to break the stock one.
mturcios777 is offline   Reply With Quote
Old   January 18, 2013, 12:39
ris
ri
Thanks for the quick response, I will attempt to get something working soon.
Total heat release rate - variation not expected Bufacchi OpenFOAM Running, Solving & CFD 14 May 15, 2020 06:35
Openfoam Ubuntu 12.04 Unmet dependencies slls33 OpenFOAM Installation 10 April 9, 2013 04:16
Troubles with heat release rate Xavier Ponticq CFX 4 September 12, 2012 18:49
Laminar Finite-rate model Reaction Heat Release adjustment lam.nguyen FLUENT 0 March 6, 2012 20:52
Diesel combustion simulation ( Heat release rate) venkatesh Siemens 2 April 29, 2009 07:38
