Initial Residual for p too high!
Like Tree20Likes
  • 18 Post By chegdan
  • 1 Post By immortality
  • 1 Post By andrei.cimpoeru
Old   March 5, 2013, 03:58
Default Initial Residual for p too high!
Nikesh Bhattarai
nikesh is an unknown quantity at this point
Hi all,
I am simulating a simple 2D flat plate flow in OpenFoam using simpleFOAM to validate a new turbulence model that I would like to implement here. This new turbulence model is a slight modification of the kOmegaSST model which includes few new terms into the nut equation.
Results from kOmegaSST model are all OK! However, when I use this new model for the same grid, my initial pressure residuals oscillate around a pretty high value, at around 0.03 while the initial U,k and omega residuals are all at a reasonable convergence criterion, at around 10^-5.
This is not making much sense to me. Because, after some iterations(about 6~7,000) when I extract the results (even without reaching the convergence tolerance) and compare, they don't yet seem so weird or deviating highly from that of the SST's results.
I have checked my code numerous times, doesn't seem to have any problems in there.
Could there be a problem with the solvers I chose?
I am as well wondering how the p-residual is calculated in simpleFOAM.
I would highly appreciate any insights into this!
Thanks!
Nikesh
These are my settings and I've used the same for kOmegaSST (in the pic attached).
nikesh is offline   Reply With Quote
Old   March 5, 2013, 04:17
immortality's Avatar
Ehsan
immortality is on a distinguished road
hi
Test for one or two order lower p tolernces than U,...
1e-9 or 1e-10
immortality is offline   Reply With Quote
Old   March 5, 2013, 05:23
Nikesh Bhattarai
Thanks!
Tried, yet not much of a difference.
Old   March 9, 2013, 15:51
AndreiCFD
andrei.cimpoeru is on a distinguished road
Hi
Basically I am having the same problem.... I just want to ask you if you managed to do it in the end. I am simulating the flow over an aerofoil using k omega sst and simpleFoam with wall functions..........
Have you got any ideas?
Thanks
Andrei
andrei.cimpoeru is offline   Reply With Quote
Old   March 10, 2013, 00:35
Nikesh Bhattarai
Hii Andrei,
Well, I am still stuck with the same problem. Obviously higher p-residual means mass is not being conserved so well somewhere in the cells. You might want to look into your boundary conditions once more. Basically that is what I am trying to do too. And the schemes and type of mesh you are using for airfoil flow.
Old   March 10, 2013, 06:28
AndreiCFD
Hi
Ok I understand . I am using k omega sst , wall functions and simpleFoam solver ..... I have changed my boundary conditions many times still nothing......for example how you o file looks like and something that I don't understand : how do you calculate
the turbulent kinetic energy K and the rate of dissipation W(omega).......
thanks
Andrei
Old   March 10, 2013, 09:56
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Nick,
There are some strategies that I would try to get these residuals down to something you would like.
  1. Lower your pressure relTol by an order of magnitude compared to U i.e. relTol = 0.001 for P and relTol = 0.01 for U.
  2. Without knowing the mesh you are using you may need to increase the nonorthogonal corrector by 1 or 2. if you are using a tet mesh...then there are many things you can do.
  3. Use first order schemes to start with (you will move to higher order ones later)
  4. Obtain an initital velocity field with potentialFoam
  5. Using simpleFoam, the intial condition from potentialFoam, and first order schemes...turn turbulence OFF and once convergence seems to bottom out, turn turbulence on while the simulation is running
  6. Once a steady-state is obtained, stop the simulation, switch to second order schemes and restart the simulation with turbulence on and see if that helps
There are a lot of other strategies that you can try, but this one might be sufficient. Without knowing more details like divergence schemes; mesh structure and checkmesh results; y+ values; and boundary conditions there is not much to add on my part.
I would look at the thread http://www.cfd-online.com/Forums/ope...-problems.html and then move on to a search of the forum. There are many threads about simpleFoam convergence...but my list of threads is not in front of me right now. good luck.
kiddmax, fumiya, Alhasan and 15 others like this.
chegdan is offline   Reply With Quote
Old   March 15, 2013, 04:17
Ehsan
how can decrease the initial residuals for p in unsteady problems when relaxations are not applicable?
JohnMex likes this.
Old   May 25, 2017, 02:52
Thodoris
teodm is on a distinguished road
Hello guys,
I am running a simulation of a flow over two wings. My simulation is 3d.I check the mesh and there is no error. I am using freestream bc and wall functions. Solver is simplefoam and turbulence model spalart almaras dudes. The problem is when I ran with coarse mesh the solution converge but when I ran with finer mesh the pressure residuals don't fall under 10^-5 they stop at about 2*10^-4.I used snappyhexmesh for the mesh. Any advice would be useful thank you in advance.
Thodoris
teodm is offline   Reply With Quote
Old   May 25, 2017, 03:58
AndreiCFD
Originally Posted by teodm View Post
Hello guys,
Thodoris
Having low residuals it does not mean that you simulation is physical. It is quite obvious that when you increase the mesh resolution to have higher residuals since you are capturing more physics. The best thing to do is to plot pressure and friction on your wings or lift and and drag and check you the results change as you increase the mesh resolution. Also check your y+ value for Spalart model. Cheers
chegdan likes this.
Old   May 25, 2017, 17:40
Thodoris
Andrei,
Thank you a lot for your answer.I am trying to calculate the cl, cd but i am having troubles because of my geometry, which consists two wings in the same but opposite angle of attack (+- 8 degrees) so i am having problems with the normals. I hope you have an idea to face this problem.I am attaching my geometry.
Thank you very much in advance.
File Type: jpg Screenshot from 2017-01-23 14-31-26.jpg (126.4 KB, 143 views)
Old   May 26, 2017, 06:53
AndreiCFD
Andrei,
You can ask the solver to dump CL and CD for you. But instead of calculating for both configs why are you not simplifying the problem by doing just one wing starting form -8 angle of attack to +20 in order to understand the flow field. Then you can probably have a look at much more complex configs.
Cheers
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
