can't read the librairy of a modified inlet condition
Like Tree1Likes
  • 1 Post By Eloise
Old   June 10, 2013, 07:35
Default can't read the librairy of a modified inlet condition
Eloïse
Eloise is on a distinguished road
I am trying to run a simpleFoam simulation with a modified inlet condition, but it seems I can't read the library in which the inlet condition is defined. I get the following error message
--> FOAM Warning :
    From function dlLibraryTable::open(const fileName&, const bool)
    in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 96
    could not load "VelRH.so"
and of course the simulation crashes
--> FOAM FATAL IO ERROR: Unknown patchField type VelRH for patch type patch
Here is the description of my setup:
I run with OpenFOAM 2.0.x. I created a velRH directory which contains the files functionVelRHFvPatchVectorField.C, functionVelRHFvPatchVectorField.H, and the Make directory which contains the files files and options (respectively below).
LIB = $(FOAM_USER_LIBBIN)/velRH
EXE_INC = \
    -I$(LIB_SRC)/finiteVolume/lnInclude
EXE_LIBS =
The command wmake libso generate the following output and creates velRH in the location corresponding to $FOAM_USER_LIBBIN
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file functionVelRHFvPatchVectorField.C
SOURCE=functionVelRHFvPatchVectorField.C ;  g++44 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/share/apps/OpenFOAM-2.0.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/share/apps/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude -I/share/apps/OpenFOAM-2.0.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/functionVelRHFvPatchVectorField.o
'.../eloisec-2.0.x/platforms/linux64GccDPOpt/lib/velRH.so' is up to date.
Can someone help me to find out why the simulation can't load the library?
Thanks for reading this long message
Eloïse
Eloise is offline   Reply With Quote
Old   June 10, 2013, 07:53
Retired Super Moderator
Bruno Santos
Greetings Eloïse,
Try the following command, to check if the library path is within visible reach:
echo $LD_LIBRARY_PATH | grep "eloisec-2.0.x/platforms/linux64GccDPOpt/lib"
Secondly, double check if the file is really there.
And I'm assuming that you edited out what was at the "..." in ".../eloisec-2.0.x", because otherwise, that would be a real problem, since it's not a standard path
Best regards,
Bruno
Old   June 10, 2013, 08:22
Eloïse
Hello Bruno,
Thanks for your fast answer
1) The path is present in the $LD_LIBRARY_PATH
2) The file velRH.so actually exist, and it is located in the proper directory
Do you have any other idea?
And you are right, I "shortened" the path the the library directory
Regards,
Eloïse
Old   June 10, 2013, 08:46
Bruno Santos
Hi Eloïse,
Then the problem must be in the code itself. Without looking at it, it could any number of possibilities.
The only other possibility that comes to mind is the name of the library, because the traditional naming (at least from what I've seen on Linux) is to prepend "lib" to the name:
LIB = $(FOAM_USER_LIBBIN)/libvelRH
Best regards,
Bruno
Old   June 10, 2013, 09:59
Eloïse
Problem solved!
I shouldn't have looked that far... I just called VelRH.so instead of velRH.so in the controlDict. So classic
Thanks for the help anyway!
Regards,
Eloïse
wyldckat likes this.
Pressure boundary condition for unsteady velocity inlet DanM OpenFOAM Running, Solving & CFD 6 July 5, 2015 09:21
unsteady ramp inlet condition pepe.aero OpenFOAM Running, Solving & CFD 10 October 22, 2013 04:23
mass flow inlet condition is not properly specified in circulating fluidized bed abinashlipun FLUENT 0 April 19, 2013 02:28
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 20:28
Pressure Inlet Boundary Condition Trinity_psu FLUENT 0 June 1, 2005 14:15
