divSchemes in interfoam
Like Tree2Likes
  • 2 Post By santiagomarquezd
Old   March 29, 2013, 05:59
Default divSchemes in interfoam
giack is on a distinguished road
Hi to all,
I'm new in the use of OpenFoam and i have two question about the scheme used in interfoam.
1)why only the divergence is discretized with a TVD scheme?
2)why the DamBreak tutorials choose two different limiter function for div(rho*phi,U) e div(phi,alpha) ?
thank to all
giack is offline   Reply With Quote
Old   April 1, 2013, 11:15
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi Giack, my humble contribution,
Originally Posted by giack View Post
Hi to all,
Since in temporal and laplacian schemes the linear interpolation is enough stable and accurate (2nd order). The necessity of TVD schemes appears due to the advection.
Each div term is different in general. For example you could have a flow where the velocity is almost a fixed field, so that, you could even use the linear scheme, meanwhile the void fraction is changing and stabilization is required, then a TVD scheme is needed.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   April 2, 2013, 04:00
it's all clear,thank you very much for your explanation
divscheme, interfoam, limitedlinear, tvd, vanleer
InterFoam stops after deltaT goes to 1e14 francesco_b OpenFOAM Running, Solving & CFD 9 July 25, 2020 06:36
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 15:26
Perfect fluid implementation - interFoam Gaetano OpenFOAM Programming & Development 7 January 26, 2013 12:54
Segmentation fault in interFoam run through openMPI voingiappone OpenFOAM 16 November 2, 2011 06:49
Open Channel Flow using InterFoam type solver sxhdhi OpenFOAM Running, Solving & CFD 3 May 5, 2009 21:58
