cavityClipped Compler problem
Old   October 23, 2013, 11:25
Default cavityClipped Compler problem
ok
Maimouna is on a distinguished road
I got problem when I try icoFoam for cavittyClipped, I got this type of problem
--> FOAM FATAL ERROR:
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux : 0.0041361
Specified mass inflow : 4.90392e-05
Specified mass outflow : 4.82345e-05
Adjustable mass outflow : 0
From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p
in file cfdTools/general/adjustPhi/adjustPhi.C at line 118.
FOAM exiting
I don't understand what does it mean.
I checked blockMesh and it was fine.
Best regards
Maimouna is offline   Reply With Quote
Old   October 24, 2013, 06:02
Artur's Avatar
Artur
Artur will become famous soon enough
This problem usually occurs when there is a problem with the boundary conditions definition - basically there is a net flux that cannot be balanced and so continuity equation cannot be satisfied.
Did you follow the tutorial to the letter? Are you sure the movingWall patch was not assigned a velocity component that "pumps" some fluid into your domain? Are all the stationary walls assigned a fixedValue (0 0 0) BC?
Best wishes,
A
Artur is offline   Reply With Quote
[Other] engineFoam new mesh problem ayhan515 OpenFOAM Meshing & Mesh Conversion 5 August 10, 2015 08:45
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
