A question on implementing the actuationDisk to the pisoFoam solver
Old   February 11, 2013, 13:52
Default A question on implementing the actuationDisk to the pisoFoam solver
Frank Yu
frankyux is on a distinguished road
Hi folks,
I have a question on implementing the actuationDisk to the pisoFoam solver. Since I didn’t use OpenFoam too much and don’t familiar with C++, my questions may sounds stupid.
I’m currently using OpenFoam 2.0.., I can find the implementation of actuationDisk under simpleFoam, namely windSimpleFoam, and this is my starting point.
My first attempt was, in the pisoFoam.C, first include #include "IObasicSourceList.H". Then add the actuationDisk to the right-hand-side of the UEqn.
#include "fvCFD.H"
#include "singlePhaseTransportModel.H"
#include "turbulenceModel.H"
int main(int argc, char *argv[])
    #include "setRootCase.H"
    #include "createTime.H"
    #include "createMesh.H"
    #include "createFields.H"
    #include "initContinuityErrs.H"
    IObasicSourceList actuationDisks(mesh);
    Info<< "\nStarting time loop\n" << endl;
    while (runTime.loop())
        Info<< "Time = " << runTime.timeName() << nl << endl;
        #include "readPISOControls.H"
        #include "CourantNo.H"
        // Pressure-velocity PISO corrector
            // Momentum predictor
            fvVectorMatrix UEqn
                fvm::ddt(U)
              + fvm::div(phi, U)
              + turbulence->divDevReff(U)
            // Add resistance on the actuation disks
            actuationDisks.addSu(UEqn());
            UEqn.relax();
            if (momentumPredictor)
                solve(UEqn == -fvc::grad(p));
            // --- PISO loop
        turbulence->correct();
        runTime.write();
        Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
            << "  ClockTime = " << runTime.elapsedClockTime() << " s"
            << nl << endl;
    //Info<< "End\n" << endl;
After the above modification, I got the following error message:
pisoFoam.C: In function ‘int main(int, char**)’:
pisoFoam.C:77: error: no match for call to ‘(Foam::fvVectorMatrix) ()’
where my Line77 refers to actuationDisks.addSu(UEqn());Does this mean that there is something wrong with the format of my UEqn?
I also tried to write my UEqn separately as UEqn.H, and replace the one in psioFoam,
  tmp<fvVectorMatrix> UEqn
        fvm::div(phi, U)
However, I got the following error message:
In file included from pisoFoam.C:81:
UEqn.H: In function ‘int main(int, char**)’:
UEqn.H:13: error: ‘class Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >’ has no member named ‘relax’
pisoFoam.C:97: error: ‘class Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >’ has no member named ‘A’
pisoFoam.C:99: error: ‘class Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >’ has no member named ‘H’
This one I think is because in piso loop it needs UEqn.A() and UEqn.H().
For now I just want to create a very simple example that I can involve actuationDisk in piso algorithm, anyone had this experience or any thoughts?
Thanks in advance.
Regards
Frank
frankyux is offline   Reply With Quote
Old   February 11, 2013, 13:54
Frank Yu
I’m currently using OpenFoam 2.0.1. A typo.
Old   February 12, 2013, 00:51
Hanzo is on a distinguished road
I am also not that skilled in c++ but I wonder what you want to access using
UEqn()
UEqn is a fvVectorMatrix, which itsel is defined as
in http://foam.sourceforge.net/docs/cpp/a04523_source.html
And here you can find a list of all public member functions of this type
http://foam.sourceforge.net/docs/cpp/a04525_source.html (starting line 115)
So you can access properties writing UEqn.source(), UEqn.internalCoeffs(), UEqn.psi() and so on. If your function addSu() expects a variable of type
fvVectorMatrix just try something like addSu(UEqn) or addSu(&UEqn).
Hope that helps.
Best,
Hanzo
Hanzo is offline   Reply With Quote
Old   February 12, 2013, 10:26
Frank Yu
Thanks for your reply. Just wondering why it works fine with windSimpleFoam but doesn't work here.
Old   April 28, 2013, 10:11
su_junwei's Avatar
su junwei
su_junwei is on a distinguished road
Send a message via MSN to su_junwei
They different, in your implementation, UEqn is an fvMatrix type, however in the second implemenation, UEqn is an tmp type, you have to convert it to fvMatrix type to use actuationDisks.addSu, and thus, use UEqn()(to get its object of tmp)
su_junwei is offline   Reply With Quote
different results between serial solver and parallel solver wlt_1985 FLUENT 11 October 12, 2018 08:23
Problem implementing CVODE ODE solver markusrehm OpenFOAM 20 October 13, 2010 17:02
Question abt. the Riemann analytic solver jinwon Main CFD Forum 0 July 16, 2007 14:11
question about implementing boundary conditions saygin Main CFD Forum 0 July 6, 2006 07:08
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
