No Velocity Residuals in interPhaseChangeFoam
Old   February 20, 2013, 13:51
Smile No Velocity Residuals in interPhaseChangeFoam
Daniel Rodriguez Calvete
DanielRCalvete is on a distinguished road
Hello Everybody,
I am running the the solver interPhaseChangeFoma using the same FvSolution setup of the CavitatingBullet tutorial. The problem is that the residuals of velocity are not written in the log-file during/after the simulation. Anybody knows how to setup the FvSolution to obtain the velocity residuals in this case, or if it is possible or not obtain this residuals from this solver?
I need to check the velocity residuals for my project, it is very important for me to know this.
Thank you in advance
DanielRCalvete is offline   Reply With Quote
Old   April 8, 2013, 07:28
abe
ABE
abe is on a distinguished road
The main reason could be that the velocity equation UEqn is not solved.
You may change the momentumPredictor condition in System/fvSolution file--PIMPLE entity from 'no' to 'yes'. So, the velocity equations will be solved and you can see their results.
abe is offline   Reply With Quote
judging convergence through residuals MachZero Main CFD Forum 7 December 25, 2012 12:18
How to calculate Velocity? Kali Sanjay Phoenics 1 May 1, 2006 13:57
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
