how to apply totalPressure BC for more stability?
Old   April 8, 2013, 17:13
Default how to apply totalPressure BC for more stability?
immortality's Avatar
Ehsan
immortality is on a distinguished road
I have an inlet patch that want to total pressure be constant on it.
but the pressure goes very low and velocity goes very high.
how to correct this situation?
is there another way to apply constant total pressure without this instability problem?
experiences are appreciated.thanks.
immortality is offline   Reply With Quote
Old   April 8, 2013, 21:55
Chris L
vbchris is on a distinguished road
what are your other BC's? whats the mesh look like?
vbchris is offline   Reply With Quote
Old   April 9, 2013, 04:50
Ehsan
hi
Its a rectangular(2d) tube with large length tha initially is full of air.one side opens to high pressure fluid and i expect a shock wave to originate (like shock tube)
I want to write total pressure code by myself.
But i'm not sure about which variables should be read from domain(extrapolate from internal domain) and which should set a formula for them.
I assumed so far that velocity be read from internal domain at have set isentropic relations for pressure and temperature(by knowing total values of p and T) But it seems somewhat unstable.
I read a thesis and it seems that p should be extrapolated from inside.but i think in this manner may no shock comes to existence because pressure on patch and internal domain will be the same.
Which combination is true and i should assign?
Thanks.
Old   April 9, 2013, 16:47
Ehsan
i tested second scenario when p is zeroGradient.but its like U zeroGradient and U goes very high.
How should use total pressure then?
Has anyone any experience to share?
Old   April 10, 2013, 05:54
Ehsan
has anyone had some experience or can help anyway or any hint or thought?!
Totalpressure Ansys Leuchte CFX 2 April 9, 2013 18:56
when I use multi block the condition of stability can not be fulfilled mostafa_khan FLOW-3D 2 April 19, 2012 12:17
Channel flow- How to apply "Translational Periodicity" Giorgitseli CFX 3 May 30, 2011 06:17
stability and number of processors ?? sersunzo OpenFOAM Running, Solving & CFD 0 June 9, 2009 11:45
Solving linear stability eq. K S Chang Main CFD Forum 3 January 19, 2004 16:01
