sonicFoam terminal error after mapping from consistent mesh
Old   May 14, 2013, 04:54
Default sonicFoam terminal error after mapping from consistent mesh
Spaceprofessor is on a distinguished road
Hi Everyone,
I am ahving a problem with a supersonic simulation. I am simulating a land speed record vehicle at roughly 1000 mph.
I have already got results over a coarse mesh, which I have successfully mapped to a more refined mesh. This completes with no errors, and viewing in paraView looks exactly the same as the source case except more refined (obviously).
My problem lies when I attempt to run sonicFoam. SonicFoam initially runs fine, then runs into a terminal error. My log files show that sonicFoam solves each of the fields until it gets to P, where it says that my solutionFv dictionary expects a scalar but instead shows "Nan".
I have spoken to my supervisor and can not figure out what this means. Any help would be very much appreciated.
Thanks
Edit: I should probably mention that my residuals in the previous fields are 0.
Last edited by Spaceprofessor; May 14, 2013 at 05:02. Reason: Forgot to mention residuals.
Spaceprofessor is offline   Reply With Quote
mapfields, nan, sonicfoam
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
