Problem running OpenFOAM 2.2.x in parallel in Centos 5
Like Tree35Likes
Old   July 4, 2014, 02:32
greg.cfd is on a distinguished road
Hello Bruno,
Sorry for the late reply. Actually the link that you provided solved the problem for my case.
More specific I followed the instructions in the last post of the thread and then the instructions in the second post of the following thread:
http://www.cfd-online.com/Forums/ope...e-openmpi.html
Now I can run OpenFoam 2.3.0 in parallel, however I can not use decomposePar. So for now I use decomposePar from OpenFoam 2.1.1
Thanks a lot for the help!
Best regards,
Greg
greg.cfd is offline   Reply With Quote
Old   September 9, 2014, 09:37
Dr. Alexander Vakhrushev
makaveli_lcf is on a distinguished road
Send a message via ICQ to makaveli_lcf
Hi guys!
For me the tip from linnemann
Originally Posted by linnemann View Post
Hi
I installed a virtual machine and found the same problem with mpirun.
To fix it you need to have the system gcc and gcc-c++ installed.
Otherwise you will get a compile error.
So here comes the fix
rm -rf $FOAM_EXT_LIBBIN/../../linux64Gcc/openmpi-1.6.3
cd $FOAM_INST_DIR/ThirdParty-2.2.x
./Allwmake
cd $FOAM_SRC/Pstream/dummy
wclean
cd ../mpi
wclean
cd ..
./Allwmake
After that it was working for me.
I will have a centFoam version up with the fixes, but it will take some time to upload etc.
worked well to:
  1. build and run OF2.2.x on CentOS 5.9 (final)
  2. build but NOT TO RUN OF2.3.x on RHEL Server 6.4 cluster
Surprisly the solver runs well on the login node of the RHEL Server in parallel mode, but when I start it via the queueing system I get the following error message in a log file:
interFoam: relocation error: /home/avakhrushev/OpenFOAM/ThirdParty-2.3.x/platforms/linux64Gcc/openmpi-1.6.5/lib64/openmpi/mca_btl_openib.so: symbol rdma_get_src_port, version RDMACM_1.0 not defined in file librdmacm.so.1 with link time reference
mpirun has exited due to process rank 0 with PID 120795 on
node n009 exiting improperly. There are two reasons this could occur:
1. this process did not call "init" before exiting, but others in
the job did. This can cause a job to hang indefinitely while it waits
for all processes to call "init". By rule, if one process calls "init",
then ALL processes must call "init" prior to termination.
2. this process called "init", but exited without calling "finalize".
By rule, all processes that call "init" MUST call "finalize" prior to
exiting or it will be considered an "abnormal termination"
This may have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
I also tried the options suggested by the wyldckat
mpirun --mca btl tcp -np 12 interFoam -parallel
mpirun --mca btl openib -np 12 interFoam -parallel
but that does not help.
So, would you be so kind to make your suggestions, what is the reason and how can I fix this issue?
Cheers,
Alex
Best regards,
Dr. Alexander VAKHRUSHEV
Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics"
Simulation and Modelling of Metallurgical Processes
Department of Metallurgy
University of Leoben
http://smmp.unileoben.ac.at
makaveli_lcf is offline   Reply With Quote
Old   September 29, 2014, 02:45
Yejun Gong
yejungong is on a distinguished road
I met the same problem before. And it is solved by recompiling the ThirdParty (Allwclean, and then Allwmake).
makaveli_lcf likes this.
yejungong is offline   Reply With Quote
Old   November 24, 2014, 14:03
stater's Avatar
H. Omar
stater is on a distinguished road
Hi Alexander,
Did you find the solution about your issue? I have the same problem and i tried to resolve by the manner proposed by linnemann but i didn't succeed
I need help please,
Thanks
stater is offline   Reply With Quote
Old   April 21, 2015, 04:01
Dear stater,
I've just solved a problem in my case. It was:
1. Rebuilding the ThirParty with system gcc
2. Running my tasks with the mpirun options:
mpirun --mca btl ^openib --mca btl_tcp_if_include eth0 -np 12 interFoam -parallel
wyldckat likes this.
Best regards,
Old   April 21, 2015, 07:56
I also successfully installed 2.3.x git version on CentOS 5.9 just following instructions:
https://openfoamwiki.net/index.php/I...CentOS_SL_RHEL
Thank you, Bruno! )))
Best regards,
Old   May 6, 2016, 04:40
Fengjiao Bian
jiaojiao is on a distinguished road
Hi
./Allwmake
wclean
cd ../mpi
wclean
cd ..
./Allwmake
I follow the steps to fix the same problem,but I can't finish the last Allwmake process. It shows cannot find the mpi.h file.I don't kown what to do.Could you give me some ideas?Thanks!
jiaojiao is offline   Reply With Quote
Old   May 8, 2016, 15:04
Retired Super Moderator
Bruno Santos
Quick answer: Please provide more specific details. For example:
  1. Which exact Linux Distribution and version are you using?
  2. Which OpenFOAM version are you trying to install?
  3. Which installation instructions did you follow for installing OpenFOAM?
Old   May 10, 2016, 01:47
Fengjiao Bian
Thank you for your quick answer, Bruno. The version of OpenFOAM I am trying to install is 2.2.2 with Red Hat 4.8.I post a new thread,
http://www.cfd-online.com/Forums/ope...tml#post599384. I pasted some information in it.
Thank you for your help,
best regards,
Jiaojiao
Old   June 27, 2016, 11:17
Tenglubao
philocfd is on a distinguished road
Hi
./Allwmake
wclean
cd ../mpi
wclean
cd ..
./Allwmake
This worked well and fixed my problem, Thank you!
philocfd is offline   Reply With Quote
Old   July 2, 2016, 13:00
Default Same problem appears in OF1606+
  #31
ali alkebsi
kebsiali is on a distinguished road
Dear all,
I have the same problem with the new OF1606+
I tried which mpirun and it is the one included with the OF1606+
I can't wclean and allwmake the mpi becuase of permissions under docker containers
Any ideas please
kebsiali is offline   Reply With Quote
Old   October 12, 2018, 00:24
Saleh Abuhanieh
Saleh Abuhanieh is on a distinguished road
Originally Posted by PeterX30 View Post
@ Bruno,
thank`s a lot for your suggestion. Obviously Debian Wheezy has problems with openmpi 1.6.3 or viceversa. Following your proposal, to use Wheezy`s own openmpi (1.4.5), fixed the problem. I changed to:
"export WM_MPLIB= SYSTEMOPENMPI"
in "OpenFOAM-2.2.x/etc/bashrc", recompiled and after that it worked.
Best Regards,
Peter
Hi Foamers,
I just wanted to highlight that the above solution is still valid.
I had the same problem with foam-extend 4.0, I think due to have more than one version of mpi in my machine.
I've changed the WM_MPLIB for SYSTEMOPENMPI
then recompiled foam
and it works!
wyldckat and amuzeshi like this.
Saleh Abuhanieh is offline   Reply With Quote
Old   September 21, 2019, 04:37
Ali Shayegh
amuzeshi is on a distinguished road
Hi
./Allwmake
wclean
cd ../mpi
wclean
cd ..
./Allwmake
I use foam-extend-4.0. There is no 'PStream' directory under $FOAM_SRC in order to make the changes that you've mentioned.
safranyikf likes this.
amuzeshi is offline   Reply With Quote
Old   December 9, 2020, 08:44
Ferenc Safranyik
safranyikf is on a distinguished road
Hi linnemann,
I faced with exactly the same problem on Ubuntu 20.04 with HELYX-OS 2.4 and OpenFoam 4.1.
I found your solutions which was worked for others as well, however in case of my setup there are no directories as you mentioned hence I am not able to run the suggested commands. Do you have any idea how should I modify your code?
Thanks in advance, Feri
safranyikf is offline   Reply With Quote
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 19:12
RSH problem for parallel running in CFX Nicola CFX 5 June 18, 2012 18:31
Problem in running job in parallel Tarak OpenFOAM 0 March 19, 2011 20:34
Problem running a parallel fluent job on local machine via mpd highhopes FLUENT 0 March 3, 2011 05:07
Running Problem using Openfoam solver cfd_staruser OpenFOAM 5 August 14, 2009 02:28
