Rotating impeller with fluid inlet on it
Old   July 31, 2013, 07:21
Default Rotating impeller with fluid inlet on it
Bayard Morales
bbmorales is on a distinguished road
Hello, guys
I would like to know if it is possible to simulate an impeller with a fluid inlet over it.
Think about a garden sprinkler (but single phase). That would be a good image of it.
Any ideas or examples?
I am still not very experienced with OF, still too attached to CFX/Fluent way of thinking:
- can you define some point fluid mass sources or you need to define proper inlets (BC's) for each inlet? As the mass flow is low and the inlet is small, I would go for point source, but don't know if it is possible.
Many thanks
Bayard
bbmorales is offline   Reply With Quote
Rotating body force in fluid dl6tud OpenFOAM Running, Solving & CFD 2 October 11, 2013 03:21
Maintaining Static Pressure at Fluid Flow Inlet cdevalve FLUENT 3 January 14, 2012 00:11
How to choose the mean diameter value for dispersed fluid? creddy_trddc CFX 1 October 30, 2011 04:30
Fluid in a rotating cylinder Fluid Novice Main CFD Forum 1 December 17, 1998 17:25
