Dumping matrices from OpenFOAM
Like Tree4Likes
  • 1 Post By kawechel
  • 3 Post By j-avdeev
Old   August 6, 2013, 07:25
Default Dumping matrices from OpenFOAM
kawechel is on a distinguished road
Hello -
I would like to dump matrices from an OpenFOAM solver run (in something like Matrix Market, Harwell-Boeing or COO formats), so that I can use them as input for a new, stand-alone solver. The idea is to compare the performance of this new solver directly with those already available in OpenFOAM (and on a problem that I am currently using OpenFOAM for), without the need to integrate it.
Does anyone know how I can do this? Some other CFD applications that I have used in the past have options such as "dump_matrix" or similar, but I have not found anything similar for OpenFOAM.
Any help with this would be greatly appreciated.
thanks,
Kawechel
Elius likes this.
kawechel is offline   Reply With Quote
Old   August 8, 2013, 08:49
In response to my own post:
after a lot of trawling through forum posts, I found a way to dump matrices using gdbOF. I have tried the approach with the simple scalarTransportFoam example, and I can indeed export the matrix in Octave/Matlab readable format.
Kawechel
Old   February 1, 2014, 11:52
Avdeev Evgeniy
j-avdeev will become famous soon enough
Send a message via Skype™ to j-avdeev
Iliya Marchevsky made lab work - simple example (on basis of icoFoam solver source code), which shows way how you can save matrices from OF to text file.
Probably, this example useless in current state and for using you have to modify it - for example, now it saves matrices as dense and for mesh 1000x1000 elements you can run out of memory.
Hope will helpful for someone.
Regards,
Evgeniy Avdeev.
wyldckat, sharonyue and Alee reza like this.
j-avdeev is offline   Reply With Quote
Old   March 7, 2014, 22:52
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi, you can do it at debug time using gdbOF.
Regards
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
matrix, solver
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 10 May 13, 2018 18:28
ESI-OpenCFD Releases OpenFOAM v2.2.0 opencfd OpenFOAM Announcements from ESI-OpenCFD 13 March 30, 2013 16:52
OpenFOAM 1.6.x, 1.7.0 and 1.7.x are not fully prepared to work with gcc-4.5.x wyldckat OpenFOAM Bugs 18 October 21, 2010 05:51
openfoam 1.5-dev on opensuse10.3-64bit anon_c OpenFOAM 2 December 4, 2009 00:33
Issues with OpenFoam sanjibdsharma OpenFOAM 0 August 14, 2009 08:41
