interFoam rotating cylinder pressure BC problem
Old   August 8, 2013, 03:05
Question interFoam rotating cylinder pressure BC problem
Christian Butcher
chrisb2244 is on a distinguished road
I'm currently using interFoam to model a rotating cylinder containing mostly water, with air in a small fraction at the top. I initially tried using swak4Foam to create expressions for 0/U on the walls and base of my cylinder making them, for example, (-Rsin(theta), Rcos(theta), 0) for the walls, and similar for the bottom. I have since moved to rotatingWallVelocity in the hope that the wall term would change my problem, but it seems to have made no difference.
When I visualise the results (currently I only have results for a short simulated time, t around 1 second in etc, although am running a 20s duration calculation on a coarser mesh to try track this down), the velocity is set nicely on the boundaries, but then does not diffuse inwards. Instead, the vortex formed in the centre on the axis diffuses velocity outwards.
If anyone has any recommendations (preferably avoiding redesigning my mesh, but if that is necessary then so be it), I would very much appreciate your help.
My BC files are below
p.s.
Looking at my BC files again, I realise it may appear as though there is a hole in my bucket... This is not the case, although the mesh was designed to allow me to set one up, probably using a pressureOutlet condition, or something. As it stands, the outlet should (I hope) behave in exactly the same way as the bottom boundary/patch.
 object      p_rgh;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    sides
        type            fixedGradient;
    gradient        uniform 0;
    bottom
        type            fixedGradient;
        gradient        uniform 0;
    outlet
        type            fixedGradient;
        gradient        uniform 0;
    top
        type            totalPressure;
        p0              uniform 0;
        U               U;
        phi             phi;
        rho             rho;
        psi             none;
        gamma           1;
        value           uniform 0;
  object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    sides
    type    movingWallVelocity;
    axis    (0 0 1);
    origin     (0 0 0);
    omega    1;
    value    uniform (0 0 0);
   bottom
    axis    (0 0 1);
    origin    (0 0 0);
    omega    1;
    outlet
    axis    (0 0 1);
    origin    (0 0 0);
    omega    1;
    top
        type            pressureInletOutletVelocity;
Last edited by chrisb2244; August 12, 2013 at 01:39. Reason: Added an archive containing 0, constant and system directories.
chrisb2244 is offline   Reply With Quote
Old   August 12, 2013, 01:37
Christian Butcher
I now have results for a endTime=60 seconds. The velocity is in fact seeming to diffuse outwards from the centre on the surface, and then downwards through my cylinder. I still don't see why the walls are not causing a velocity to diffuse inwards from the walls.
My surface tension is being ignored using a zeroGradient BC on alpha1 as in the damBreak tutorial - is this a bad choice for my problem?
Any help is much appreciated.
interfoam rotatingwall, pressure bc
Low pressure de Laval simulation convergence problem heksel8i FLUENT 3 July 22, 2013 10:28
stagnation pressure boundary problem mbgnfrx2 STAR-CD 2 November 25, 2012 23:55
VOF method- Fluid in a rotating Cylinder Problem Krishna Sandeep FLUENT 1 July 3, 2012 16:44
Pressure problem in Interfoam danvica OpenFOAM Running, Solving & CFD 12 March 14, 2012 02:56
Problem with the pressure field using interFoam zoune OpenFOAM Running, Solving & CFD 20 February 4, 2008 18:42
