Proper initialisation of phase boundaries for interDyMFoam |
September 9, 2013, 06:40 |
Krzysztof Lamorski
Rep Power: 14 |
Hello Dear Foamers,
I am facing currently with a problem, with proper setting of initial conditions for interDyMFoam solver. For my simulation I want/have to use dynamically refined mesh. But the question is, if I can refine the mesh for time 0, to more accurately initialise the boundaries between two phases. The base coarse mesh is built from cubic cells. The shape which I try so set at the initial time with setFields is a sphere. Of course "the sphere" set by setFields in the relatively coarse base mesh is not a sphere, which influences the results of calculation substantially. I've been trying such tools like refineMesh for mesh refinement in the region where the initial sphere is located, but interDyMFoam was refining the mesh at the interface again, which resulted in very small cells, which effectively stopped the simulation due to very low timesteps. Is there any method of creating the dynamic mesh at initial time which could be used than by the solver? Best regards, Krzysztof |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 16:12 |
[ICEM] Proper way to name boundaries on 2D model for use in CFX? | RossFS | ANSYS Meshing & Geometry | 4 | November 10, 2011 02:38 |
two Phase column simulation | chemeng | OpenFOAM | 3 | August 18, 2010 12:53 |
phase lag boundaries | Jens | FLUENT | 0 | August 1, 2006 09:56 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
