Error running Propeller Tutorial
Old   February 9, 2013, 09:44
Default Error running Propeller Tutorial
Tobi
TOM01 is on a distinguished road
I'm rather new to Openfoam and trying to run the propellor tutorial.
An error occurs while running the Allrun script:
in log.createBaffles
Converting faces on zone "innerCylinderSmall" into baffles.
Found 22416 faces on zone "innerCylinderSmall"
Using master patch AMI1 at index 7
Using slave patch AMI2 at index 8
Not converting faces on non-coupled patches.
Reading geometric fields
Reading volScalarField p
Reading volScalarField nut
Reading volScalarField k
Reading volScalarField epsilon
Reading volVectorField U
--> FOAM FATAL ERROR:
Problem : Patch AMI1 starts at 1756182
Current face counter at 1756183
Are patches in incremental order?
    From function polyTopoChange::polyTopoChange(const polyMesh& mesh, const bool strict)
    in file polyTopoChange/polyTopoChange/polyTopoChange.C at line 2459.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM-2.1.1/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1  Foam::error::abort() in "/opt/OpenFOAM-2.1.1/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2  Foam::polyTopoChange::addMesh(Foam::polyMesh const&, Foam::List<int> const&, Foam::List<int> const&, Foam::List<int> const&, Foam::List<int> const&) in "/opt/OpenFOAM-2.1.1/platforms/linuxGccDPOpt/lib/libdynamicMesh.so"
#3  Foam::polyTopoChange::polyTopoChange(Foam::polyMesh const&, bool) in "/opt/OpenFOAM-2.1.1/platforms/linuxGccDPOpt/lib/libdynamicMesh.so"
 in "/opt/OpenFOAM-2.1.1/platforms/linuxGccDPOpt/bin/createBaffles"
#5  __libc_start_main in "/lib/libc.so.6"
 at /home/abuild/rpmbuild/BUILD/glibc-2.14.1/csu/../sysdeps/i386/elf/start.S:122
In log.snappyHexMesh I find
Edge intersection testing:
    Number of edges             : 1756183
    Number of edges to retest   : 57
    Number of intersected edges : 75181
Snapped mesh : cells:568602  faces:1756183  points:625033
and in system/changeDictionaryDict I see
AMI1
            type            cyclicAMI;
            nFaces          0;
            startFace       1756182;
            neighbourPatch  AMI2;
            transform       noOrdering;
            surface
        AMI2
            type            cyclicAMI;
            nFaces          0;
            startFace       1756182;
            neighbourPatch  AMI1;
            surface
TOM01 is offline   Reply With Quote
Old   February 9, 2013, 13:55
Tobi
sorry, that was to early, the solution worked not really
but I found, that it really might be a bug in the tutorial
http://www.openfoam.org/mantisbt/view.php?id=593
Old   October 16, 2013, 06:44
yehanyu
yhy20081016 is on a distinguished road
You can try the latest version. I had a lot of experience on this issue. I have tried to run the propeller tutorial by using OpenFOAM 2.1.1 on Fedora, but it diverge at t=0.02s. Then I tried the latest version of OpenFOAM --- it works!
yhy20081016 is offline   Reply With Quote
propeller tutorial using AMI in OF v2.1.0 impecca OpenFOAM Pre-Processing 6 May 9, 2016 10:22
Propeller tutorial case enquiries chujeh2020 OpenFOAM 0 August 26, 2012 01:18
propeller tutorial openfoam_user OpenFOAM Running, Solving & CFD 0 February 8, 2012 04:02
Modelling a propeller tomg STAR-CCM+ 4 April 28, 2011 17:22
Looking for tutorial for rotating propeller for Marine Applications naimishharpal STAR-CCM+ 0 February 7, 2011 22:12
