Turbulrnt flow past cylinder
Old   November 7, 2013, 06:48
Post Turbulrnt flow past cylinder
sam.ho is on a distinguished road
Hi Foamers,
I set up the case of transient flow past circular cylinder with following conditions
Re = 3.6*10^6
Velocity = 3.6 m/s
turbulent intensity = 0.5%
I am getting an error as attached in a snapshot and also i have attached the 0 directory.
ControlDict is as follows.
[/*--------------------------------*- C++ -*----------------------------------*\
| \\ / O peration | Version: 2.2.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
libs
"libOpenFOAM.so"
"libincompressibleTurbulenceModel.so"
"libincompressibleRASModels.so"
application pimpleFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 1000;
deltaT 0.001;
writeControl adjustableRunTime;
writeInterval 100;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
adjustTimeStep yes;
maxCo 1;
functions
probes
// Where to load it from
functionObjectLibs ( "libsampling.so" );
type probes;
// Name of the directory for probe data
name probes;
// Write at same frequency as fields
outputControl outputTime;
outputInterval 1;
// Fields to be probed
fields
p U
probeLocations
( -6 0 0 ) // at inlet
( 30 0 0 ) // at outlet
( 18 0 0 ) // at central block
File Type: jpg Screenshot from 2013-11-07 17:09:01.jpg (78.9 KB, 22 views)
sam.ho is offline   Reply With Quote
Old   November 8, 2013, 03:28
pingat is on a distinguished road
Its a problem of your courant number as you see in your terminal picture.
your maximum courant number is set to 1 but you get some of 10^28.
It would be helpful to take a shorter write interval and have a look at some pressure peaks before the breakdown.
what's the difference between your fixed walls and walls?
greeting
pingat
pingat is offline   Reply With Quote
Old   November 8, 2013, 03:34
Default Specifying Boundary Conditions in pimpleFOAM
Hi
Here are the boundaries specified and the case geometry and mesh are shown in this snap shot attached with this mail.
Old   November 8, 2013, 03:38
greeting
pingat
Hi
I just run the case with write interval of 0.5 but the problem remains the same as before..
No change at all...
Can you tell how to resolve this problem
Old   November 8, 2013, 03:45
Post Constant and system directories of the case
Hi
Kindly find the attached system and constant directories for reference.
Old   November 8, 2013, 03:56
Originally Posted by sam.ho View Post
Hi
No change at all...
you should set your write interval to a step, that you can see what is happening at time 2.07.
there you get a time step of 10^-60 and a high courant number, so maybe there is a problem in your meshing?
maybe you could post a pressure and velocity picture at that time.
Old   November 8, 2013, 06:47
Hi ,
I am running the case but one thing i ma observing that deltaT=0.001 in control dict but its displaying deltaT of the order of 10^-7 and simulation is very slow...
Why is this so ?
As per my knowledge whichever deltaT we have specified in controlDict that value has to be come on terminal box.
Can anyone clarify this please .
Old   November 9, 2013, 04:57
if there is no convergence at the given timestep, the solver trys to take a smaller step.
Old   November 10, 2013, 23:04
Hi pingat ,
What might be the reason for non convergence ????????
Old   November 28, 2013, 21:57
kkpal is on a distinguished road
I also get this error from time to time, then I changed the mesh a little, the problem disappeared. I've no idea why.
kkpal is offline   Reply With Quote
2D modelling of flow past a rotating cylinder pds24 Main CFD Forum 1 August 21, 2015 10:50
Flow past an oscillating cylinder (Strouhal number) o_mars_2010 Main CFD Forum 8 May 23, 2014 04:25
Flow past rotating cylinder sam.ho OpenFOAM Running, Solving & CFD 4 October 10, 2013 07:49
CFD help: flow past cylinder harsha00711 Main CFD Forum 1 December 24, 2010 21:19
meshing for flow past a cylinder karthik FLUENT 1 July 15, 2005 06:17
