November 7, 2013, 06:48 |
Turbulrnt flow past cylinder
Rep Power: 12 |
Hi Foamers,
I set up the case of transient flow past circular cylinder with following conditions Re = 3.6*10^6 Velocity = 3.6 m/s turbulent intensity = 0.5% I am getting an error as attached in a snapshot and also i have attached the 0 directory. ControlDict is as follows. [/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // libs ( "libOpenFOAM.so" "libincompressibleTurbulenceModel.so" "libincompressibleRASModels.so" ); application pimpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 1000; deltaT 0.001; writeControl adjustableRunTime; writeInterval 100; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 6; runTimeModifiable true; adjustTimeStep yes; maxCo 1; functions { probes { // Where to load it from functionObjectLibs ( "libsampling.so" ); type probes; // Name of the directory for probe data name probes; // Write at same frequency as fields outputControl outputTime; outputInterval 1; // Fields to be probed fields ( p U ); probeLocations ( ( -6 0 0 ) // at inlet ( 30 0 0 ) // at outlet ( 18 0 0 ) // at central block ); } } // ************************************************** *********************** //] |
November 8, 2013, 03:28 |
Rep Power: 12 |
Its a problem of your courant number as you see in your terminal picture.
your maximum courant number is set to 1 but you get some of 10^28. It would be helpful to take a shorter write interval and have a look at some pressure peaks before the breakdown. what's the difference between your fixed walls and walls? greeting pingat |
November 8, 2013, 03:34 |
Specifying Boundary Conditions in pimpleFOAM
Rep Power: 12 |
Hi
Here are the boundaries specified and the case geometry and mesh are shown in this snap shot attached with this mail. |
November 8, 2013, 03:45 |
Constant and system directories of the case
Rep Power: 12 |
Hi
Kindly find the attached system and constant directories for reference. |
November 8, 2013, 03:38 |
#5 | |
Rep Power: 12 |
I just run the case with write interval of 0.5 but the problem remains the same as before.. No change at all... Can you tell how to resolve this problem |
November 8, 2013, 03:56 |
#6 | |
Rep Power: 12 |
there you get a time step of 10^-60 and a high courant number, so maybe there is a problem in your meshing? maybe you could post a pressure and velocity picture at that time. |
November 8, 2013, 06:47 |
Rep Power: 12 |
Hi ,
I am running the case but one thing i ma observing that deltaT=0.001 in control dict but its displaying deltaT of the order of 10^-7 and simulation is very slow... Why is this so ? As per my knowledge whichever deltaT we have specified in controlDict that value has to be come on terminal box. Can anyone clarify this please . |
November 9, 2013, 04:57 |
Rep Power: 12 |
if there is no convergence at the given timestep, the solver trys to take a smaller step.
November 10, 2013, 23:04 |
Rep Power: 12 |
Hi pingat ,
What might be the reason for non convergence ???????? |
November 28, 2013, 21:57 |
I also get this error from time to time, then I changed the mesh a little, the problem disappeared. I've no idea why.
2D modelling of flow past a rotating cylinder | pds24 | Main CFD Forum | 1 | August 21, 2015 10:50 |
Flow past an oscillating cylinder (Strouhal number) | o_mars_2010 | Main CFD Forum | 8 | May 23, 2014 04:25 |
Flow past rotating cylinder | sam.ho | OpenFOAM Running, Solving & CFD | 4 | October 10, 2013 07:49 |
CFD help: flow past cylinder | harsha00711 | Main CFD Forum | 1 | December 24, 2010 21:19 |
meshing for flow past a cylinder | karthik | FLUENT | 1 | July 15, 2005 06:17 |
