January 14, 2014, 22:04 |
Flow around cylinder at Re=40
leeminjae
Hello ladies & gentlemen
I'm working to simulate "flow around cylinder at Re=40" I generated the mesh using Gambit. It's a very simple simulation. the objective of simulation is to get a good matching results of Cd & Cl But I think my result is not that matching with an another paper. I don't know what's wrong. I attached my code below. And another problem, Co(Courant Number) is around 1.6 Is it O.K ? The property I used Ux 0.071576 (m/s) Diameter 0.01 (m) Nu 1.7894e-05 Re 40 I'm sorry to attach my file not comfortably. I don't know how to attach my code with files. I'm looking forward to taking advice from you. /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ forceCoeffs1 { type forceCoeffs; functionObjectLibs ( "libforces.so" ); outputControl outputTime; log yes; patches ( cy ); pName p; UName U; rhoName rhoInf; // Indicates incompressible log true; rhoInf 1.225; // Redundant for incompressible liftDir (0 1 0); dragDir (1 0 0); CofR (0 0 0); // Axle midpoint on ground pitchAxis (0 0 1); magUInf 0.4; lRef 0.01; // Wheelbase length Aref 0.0001; // Estimated } // ************************************************** *********************** // /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { down { type symmetryPlane; } up { type symmetryPlane; } wall { type zeroGradient; } back { type symmetryPlane; } front { type symmetryPlane; } outlet { type fixedValue; value uniform 0; } inlet { type zeroGradient; } } // ************************************************** *********************** // FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { down { type symmetryPlane; } up { type symmetryPlane; } wall { type fixedValue; value uniform (0 0 0); } back { type symmetryPlane; } front { type symmetryPlane; } outlet { type zeroGradient; } inlet { type fixedValue; value uniform (0.071576 0 0); } } FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // libs ( "libOpenFOAM.so" "libincompressibleTurbulenceModel.so" "libincompressibleRASModels.so" ); application icoFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 150; deltaT 0.005; writeControl timeStep; writeInterval 200; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; functions { #include "forceCoeffs" } // ************************************************** *********************** // /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default backward; } gradSchemes { default Gauss linear; grad(p) Gauss linear; } divSchemes { default none; div(phi,U) Gauss linear; } laplacianSchemes { default none; laplacian(nu,U) Gauss linear orthogonal; laplacian((1|A(U)),p) Gauss linear orthogonal; } interpolationSchemes { default linear; interpolate(HbyA) linear; } snGradSchemes { default orthogonal; } fluxRequired { default no; p ; } // ************************************************** *********************** // /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0; } U { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0; } } PISO { nCorrectors 2; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; } // ************************************************** *********************** // |
January 16, 2014, 21:22 |
Josh
Rep Power: 12 |
This could be any number of issues. If you post your case as a zip file, people might take a look at it for you.
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
1 Was FSI for a flow over a cylinder | vmlxb6 | CFX | 17 | May 16, 2011 02:29 |
Moving a Cylinder in cross flow after solving Dynamics equations of motion | maruthamuthu_venkatraman | OpenFOAM | 1 | November 19, 2009 13:55 |
Flow over a flat plate & Flow over a cylinder | cfdxue | Main CFD Forum | 0 | November 26, 2007 23:26 |
Flow over a cylinder | Anna | Main CFD Forum | 9 | March 24, 2006 14:32 |
