Time step continuity
Old   January 26, 2014, 10:19
Default Time step continuity
erik gustafsson
guserik is on a distinguished road
Hello
I got problem with time step continuity when try to run rhoPimpleFoam, i have 2 regions with 8 bar in pressure differnce. When i start my simulation i got really high error directly in the second iteration step. I have tried to change alot of parameters in my fvSolution and fvSchemes without any sucess.
time step continuity errors : sum local = 0.463969, global = -0.463969, cumulative = -5.10366
rho max/min : 6.5 1.05679
|  \\    /   O peration     | Version:  2.2.2                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss upwind limited 1;
    div(phi,h)      Gauss upwind;
    div(phi,k)      Gauss upwind;
    div(phi,epsilon) Gauss upwind;
    div((muEff*dev2(T(grad(U))))) Gauss linear;
    div(phi,K)      Gauss linear;
laplacianSchemes
    default         none;
    laplacian(muEff,U) Gauss linear corrected;
    laplacian(Dp,p) Gauss linear corrected;
    laplacian(alphaEff,h) Gauss linear corrected;
    laplacian(DkEff,k) Gauss linear corrected;
    laplacian(DepsilonEff,epsilon) Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         yes;
    p               ;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    rho
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-10;
        relTol          0;
    rhoFinal
        $rho;
        tolerance       1e-10;
        relTol          0;
    U
        solver          smoothSolver;
        smoother        GaussSeidel;
        nSweeps         2;
        tolerance       1e-10;
        relTol          0;
    UFinal
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-10;
        relTol          0.01;
    p
        solver          GAMG;
        tolerance       1e-11;
        relTol          0;
        nPreSweeps      1;
        nPostSweeps     1;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 100;
        agglomerator    faceAreaPair;
        mergeLevels     1;
  maxIter 1500;
    pFinal
        $p;
        relTol          0;
    h
        solver          PBiCG;
        tolerance       1e-10;
        relTol          0;
    hFinal
        solver          PBiCG;
        tolerance       1e-10;
        relTol          0;
    "(k|epsilon)"
        solver          PBiCG;
        tolerance       1e-5;
        relTol          0.1;
    "(k|epsilon)Final"
        solver          PBiCG;
        tolerance       1e-10;
        relTol          0.1;
PIMPLE
    nOuterCorrectors 3;
    nCorrectors     3;
    nNonOrthogonalCorrectors 1;
    momentumPredictor yes;
    rhoMin          rhoMin [ 1 -3 0 0 0 ] 0.5;
    rhoMax          rhoMax [ 1 -3 0 0 0 ] 6.5;
relaxationFactors
    default         0;   //Other tries :
    p               0.01; //  0.3 0.2 0.3
    U               0.01; //  0.5 0.2 0.5
    nuTilda         0.7; //  0.6 0.4 0.6
    h               0.01; //  0.6 0.4 0.3
    rho             0.05; // 0.05 0.05 0.025
    hFinal          0.01; //  0.6 0.6 0.3
    "(U|nuTilda)Final"  0.07; // 0.6  0.4 0.6
guserik is offline   Reply With Quote
Old   January 26, 2014, 10:48
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
see these links:
http://openfoamwiki.net/index.php/HowTo_debugging
http://www.cfd-online.com/Forums/ope...rintstack.html
perhaps it's because of your mesh, your BCs and ....
what is the error exactly?
adambarfi is offline   Reply With Quote
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 00:36
