mixing fresh-saltwater
Old   February 6, 2014, 07:16
Default mixing fresh-saltwater
dell-ocqa aronne
aronne030389 is on a distinguished road
Hi, i'm really new to OpenFoam and i'm looking for a solver that can simulate the mixing between salt water and fresh water. In principle it's just one phase and i have to solve the transport equation for the solute (NaCl) that affects the density,there's any specific solver??. I look to interMIxingFoam putting phase2 fresh and phase3 salt water and setting the diffusion coeff between them. But i don't understand the physic behind this solver : that coeff of diffusion can be treat as molecular diffusion ? which is the transport equation that rule the process? ... and what about twoLiquidMixingFoam....thanks very much
aronne030389 is offline   Reply With Quote
Old   February 6, 2014, 07:47
Tommy V
Villo is on a distinguished road
Hi aronne,
i think twoLiquidMixingFoam is perfect for your issue.
Is a solver for mixing between two fluids (single phase) with different diffusion properties.
You will see that the transport equation will use the scalar alpha as ratio between the two different densities.
You can explore the solver here
applications/solvers/multiphase/twoLiquidMixingFoam/
Tommy
Villo is offline   Reply With Quote
Old   February 6, 2014, 13:41
dell-ocqa aronne
Hi Tommy Thank you,
i loked into the solver folder. Am i right saying that i can consider molecular diffusion between saltwater and freshwater as the Dab coefficients to set in the transportPropertiesDict?? then there's also a turbulence diffusion ( alphatab*turbulence->nut() ) that in my work i will not consider since my flow are laminar.
FROM fille
AlphaDiffusionEqn.H
fvScalarMatrix alpha1Eqn
fvm::ddt(alpha1)
- fvc::ddt(alpha1)
- fvm::laplacian
volScalarField("Dab", Dab + alphatab*turbulence->nut()),
alpha1
alpha1Eqn.solve();
alpha2 = 1.0 - alpha1;
rhoPhi += alpha1Eqn.flux()*(rho1 - rho2);
rho = alpha1*rho1 + alpha2*rho2;
Old   February 6, 2014, 14:01
Tommy V
This is the ./constant/transportProperties for twoLiquidMixingFoam
https://github.com/OpenFOAM/OpenFOAM...portProperties
You will see Dab [0 2 -1 0 0 0 0], or else [m^2/s]: yes, that's the molecular diffusivity.
About nut: yes, if you're in laminar you can also delete it.
Old   February 11, 2014, 10:34
dell-ocqa aronne
thank you so much , it seem to work. Have a nice job!!
Old   February 11, 2014, 10:40
Tommy V
cool! I had to work a lot on that solver, if you need any help (principally via LES models) just ask.
have fun!
Old   January 7, 2020, 09:36
Bodo1993 is on a distinguished road
have fun!
Dear Villo,
I use twoLiquidMixingFoam solver in OpenFOAM. In my setup, I have a single inlet and two outlets as shown in the attachment. The two fluids are expected to mix and exit through the outlets.
I am wondering what would be the boundary conditions for the alpha phase in this case.
I use zeroGradient or inletOutlet. Initially, it works fine since only single phase exists at the outlet boundary. However, when a mixed phase reaches the outlet boundary, I get some vortices (see attachment).
In the zero directory, I have three files only; p_rgh, U and alpha.phase1.
I would appreciate any assistance.
Thanks.
Bodo1993 is offline   Reply With Quote
What's is mixing law richard ben FLUENT 4 September 25, 2014 17:30
The mixing of freshwater and saltwater yinyueqiang FLUENT 0 February 17, 2013 23:07
Problem with Mixing plane Mitpostdoc FLUENT 0 July 26, 2011 14:31
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 17:08
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 07:16
