problem_running parallel on cluster
Old   February 28, 2014, 12:47
Default problem_running parallel on cluster
Yijiu Jiang
y_jiang is on a distinguished road
When I use "qsub" to submit my the foam.job, I got the following error
Got 8 processors.
Machines:
compute-0-3
compute-0-3
compute-0-3
compute-0-3
compute-0-3
compute-0-3
compute-0-3
compute-0-3
The OpenFabrics (openib) BTL failed to initialize while trying to
allocate some locked memory. This typically can indicate that the
memlock limits are set too low. For most HPC installations, the
memlock limits should be set to "unlimited". The failure occured
here:
Local host: compute-0-3.local
OMPI source: btl_openib_component.c:1200
Function: ompi_free_list_init_ex_new()
Device: mlx4_0
Memlock limit: 65536
My question is that is this error is due to any wrong setting or I just need to ask the administrator to make the change on memlock limits? The scripts and error information are attached. Anyone has the same problem? Thx
YJ
y_jiang is offline   Reply With Quote
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 22:51
Parallel rerun in cluster Andy_bm OpenFOAM Running, Solving & CFD 4 November 27, 2011 07:16
Parallel Solving with HPC Cluster? bah OpenFOAM Running, Solving & CFD 8 October 13, 2011 03:08
Parallel cluster solving with OpenFoam? P2P Cluster? hornig OpenFOAM Programming & Development 8 December 5, 2010 16:06
