March 14, 2014, 01:53 |
Isothermal twoPhaseEulerFoam
Onno
Rep Power: 15 |
is there any way to run twoPhaseEulerFoam without solving for heat? I don't have the necessary data and I want do not want the extra computional effort. multiPhaseEulerFoam apparently supports it, but but my case to large to try LES. Since I have a gas content in a liquid phase, the InterFOAMs are not an option. I need to resolve the flow fields for both phases. Further questions: What would happen if I just set both phases to the same temperature? Is k converted to heat via epsilon? Or does it just vanish? Thanks for the help. |
isothermal medium | myaccount | FLUENT | 0 | January 22, 2014 07:36 |
isothermal medium | myaccount | Main CFD Forum | 0 | January 22, 2014 05:42 |
Is twoPhaseEulerFoam applicable to 3D cases / delivering erroneous results? | ThomasV | OpenFOAM | 0 | November 11, 2013 08:10 |
small density change for isothermal flows | hz283 | OpenFOAM | 1 | April 6, 2013 10:05 |
twoPhaseEulerFoam | freemankofi | OpenFOAM | 0 | May 23, 2011 16:24 |
