Setting SolverPerformance in controlDict
Old   March 16, 2014, 15:51
Default Setting SolverPerformance in controlDict
Begineer is on a distinguished road
Hi everybody,
I've just started learning OpenFoam, and ran into a problem setting SolverPerformance in controlDict. From what I understand, settings in a case's controlDict is supposed to override settings in $WM_PROJECT_DIR/etc/controlDict, but this doesn't seem to happen when I try it.
What I do is:
run
cp -r $WM_PROJECT_DIR/tutorials/incompressible/icoFoam/cavity .
cd cavity/
I add the line:
SolverPerformance 2;
to the end of cavity/system/controlDict
and then:
blockMesh
icoFoam
The output I get is:
Time = 0.005
Courant Number mean: 0 max: 0
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 2.96338e-06, No Iterations 8
DILUPBiCG: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
DICPCG: Solving for p, Initial residual = 1, Final residual = 7.55402e-07, No Iterations 35
time step continuity errors : sum local = 5.03809e-09, global = 4.40722e-19, cumulative = 4.40722e-19
DICPCG: Solving for p, Initial residual = 0.523591, Final residual = 9.72352e-07, No Iterations 34
time step continuity errors : sum local = 1.07766e-08, global = 2.93897e-19, cumulative = 7.34619e-19
ExecutionTime = 0.02 s ClockTime = 0 s
However, if I open $WM_PROJECT_DIR/etc/controlDict, and set:
The output I get is something like:
Time = 0.005
DILUPBiCG: Iteration 0 residual = 1
DILUPBiCG: Iteration 1 residual = 0.153298
DILUPBiCG: Iteration 2 residual = 0.0375508
DILUPBiCG: Iteration 3 residual = 0.00820823
DILUPBiCG: Iteration 4 residual = 0.00174405
DILUPBiCG: Iteration 5 residual = 0.000357418
DILUPBiCG: Iteration 6 residual = 7.4212e-05
DILUPBiCG: Iteration 7 residual = 1.51806e-05
DILUPBiCG: Iteration 8 residual = 2.96338e-06
etc
Does anyone know why it didn't work setting the SolverPerformance in the local controlDict for the case?
Cheers,
Begineer is offline   Reply With Quote
Old   March 17, 2014, 13:46
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
I think you need to use a sub dictionary like the example below taken from the 2.2 release notes.
DebugSwitches
Regards,
Tom
tomf is offline   Reply With Quote
Old   March 17, 2014, 17:58
Hi Tom,
Thanks for the suggestion. However, when I tried it, I now get an output saying:
Create time
Overriding DebugSwitches according to controlDict
Create mesh for time = 0
Reading transportProperties
etc
I didn't get the "Overriding DebugSwitches according to controlDict" previously, so at least it reads the DebugSwitches. Unfortunately, I don't get any extra output information, so something is still missing.
Old   March 18, 2014, 09:51
Tom Fahner
Hmm just did a test and I can report the same issue with the unBoundedGauss warning in version 2.2, meaning I get the
in the log, but still get the warning. Maybe there is some bug or additional setting I am not aware of.
Old   March 18, 2014, 10:30
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
this message is produced by TimeIO.C and it seems do read the settings:
    if (controlDict_.found("DebugSwitches"))
        Info<< "Overriding DebugSwitches according to " << controlDict_.name()
            << endl;
        simpleObjectRegistry& objects = debug::debugObjects();
        const dictionary& localSettings = controlDict_.subDict("DebugSwitches");
        forAllConstIter(dictionary, localSettings, iter)
            const word& name = iter().keyword();
            simpleObjectRegistryEntry* objPtr = objects.lookupPtr(name);
Maybe it then forgets about them
But OpenFOAM quite happily reads debug switches from ~/.OpenFOAM/<VERSION>/controlDict. Though it is site-wide settings.
alexeym is offline   Reply With Quote
Old   March 18, 2014, 16:11
It seems this has already been reported as a bug:
http://www.openfoam.org/mantisbt/view.php?id=1020
(should have checked this before opening a thread, sorry)
The answer is: "The debug symbols are currently only stored for non-templated classes."
When checking SolverPerformance.C, it indeed is a template class, so I guess that explains it.
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
Residual level setting of Fluent lhlh ANSYS 2 November 17, 2012 21:35
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
Ultra high temperature? bk Siemens 2 July 19, 2005 00:01
Warning 097- AB Siemens 6 November 15, 2004 04:41
