Adaptive mesh refinement using simpleFOAM
Like Tree4Likes
  • 4 Post By olivierG
Old   March 31, 2014, 01:58
Question Adaptive mesh refinement using simpleFOAM
avinashjagdale
avinashjagdale is on a distinguished road
How to implement dynamics adaptive mesh refinement using simpleFOAM.?
avinashjagdale is offline   Reply With Quote
Old   March 31, 2014, 03:57
Paritosh Vasava
vasava will become famous soon enough
Can you explain more about your case? It would be easy to point out a solve that might suit your case.
vasava is offline   Reply With Quote
Old   March 31, 2014, 04:08
avinashjagdale
@paritosh
the flow is through a model of turbine stator cooling network . like the one in the link below.
http://3.bp.blogspot.com/-KYC-Nn3g5B...Q/s1600/29.JPG
It is a single inlet ,multiple outlet flow.
It is steady state incompressible turbulent flow using K-epsilon.
In my simulation Pressure is not converging.
I am presently reading about AMR in H.Jasak's phD thesis, and a report about icoDyMFoam.
I am wondering if AMR can be implemented in simpleFOAM as there is no simpleDyMFoam.
Old   March 31, 2014, 09:49
Olivier
olivierG is on a distinguished road
hello,
* You can switch your solution to a transient pimpleDyMFoam case, and run for a few (or more) time step, thus doing mesh adaptation, then switch to simpleFoam, keeping the mesh (just modify controlDict, fvSolution, fvScheme), i.e:
1) run with simpleFoam
2) modify system dir, and run with pimpeDyMFoam from latestTime
3) modify again to come back with simpleFoam
* Or modify the solver simpleFoam (not too difficult if you already done this once.)
Regards,
olivier
ArathoN, hua1015, arvindpj and 1 others like this.
olivierG is offline   Reply With Quote
Old   April 1, 2014, 00:39
avinashjagdale
Thank you olivier.
The first method is really a nice trick .
Will let you know my further progress.
Adaptive Local Mesh Refinement Abhishekd18 OpenFOAM Running, Solving & CFD 26 March 31, 2015 08:19
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 17:12
[snappyHexMesh] non-smooth mesh Svensson OpenFOAM Meshing & Mesh Conversion 11 January 18, 2012 09:13
customized sonicFoam for adaptive mesh refinement - how to define mass flow BCs? shockley OpenFOAM 1 December 13, 2010 04:04
Searching criteria for adaptive mesh refinement Flowee ANSYS Meshing & Geometry 1 August 6, 2010 12:43
