how to specify parallel running? (core i7 but with 6 cores running)
Like Tree1Likes
  • 1 Post By RodriguezFatz
Old   April 16, 2014, 08:57
Default how to specify parallel running? (core i7 but with 6 cores running)
Tommy Sp
vitorspadeto is on a distinguished road
Hey. Performed once the simulation using all my intel i7 processors. But coller worked with all the power vent. I'm worried, since I'm afraid of causing problems in the processor when running a simulation using all 8 processors. can cause problems? maybe burn the processor?
if I want to use only 6 processors, how should I specify the decomposePar file and the command line in the terminal? I tried the following but it gave this error:
decomposePar:
numberOfSubdomains 6;
method simple;
simpleCoeffs
n ( 3 2 1 );
delta 0.001;
Terminal:
mpirun -np 6 icoFoam -parallel > log &
Error:
--> FOAM FATAL ERROR:
[0] icoFoam: cannot open case directory "/home/s/Dropbox/Openfoam_PG/papers/libre_mechanics_tutorials/bridge/Case2pillars/processor0"
thanks all!
vitorspadeto is offline   Reply With Quote
Old   April 16, 2014, 08:59
Tommy Sp
changing the line command:
mpirun -np 8 icoFoam -parallel > log &
[4] 5142
[3] Fim da execução com status 1 mpirun -np 6 icoFoam -parallel > log
s@s-Aspire-V3-571:~/Dropbox/Openfoam_PG/papers/libre_mechanics_tutorials/bridge/Case2pillars$ [0]
[0]
[0] --> FOAM FATAL ERROR:
[0] number of processor directories = 1 is not equal to the number of processors = 8
[0]
FOAM parallel run exiting
[0]
Old   April 16, 2014, 10:25
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Hey Vitor, everything was fine, but you need to actually decompose your domain. The file "decomposeParDict" only says openfoam how the decomposition is done. Type "decomposePar" before running "mpi -np ...". The decomposePar command will create the (in your case) six directories ./processor0, ./processor/1 ... where the "cutted" domain is stored.
chrisb2244 likes this.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
solving a conduction problem in FLUENT using UDF Avin2407 Fluent UDF and Scheme Programming 1 March 13, 2015 02:02
Selecting cores independently in a dual quad core machine jalarron FLUENT 1 September 7, 2009 17:06
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
FEDORA CORE and PARALLEL processing Tuks CFX 2 August 20, 2005 11:05
