Bridgman Paradox?! Masters thesis
Old   May 26, 2014, 06:56
Default Bridgman Paradox?! Masters thesis
Kjetil
Itek is on a distinguished road
Hello!
Im working on my masters thesis, where Im looking into something that some would say is an unexpected answer.
The setup is very simple:
Step 1: Faced with the seemingly trivial physical problem with a pressurized chamber with a bar protruding the chamber walls through sealing glands, most people opts for solution 1; no resulting axial force; T =0.
Step 2: By reversing the pressure, there is 100% agreement that solution 2 gives the right answer. A compression force corresponding to the overall pistion effect.
Step 3: Most people agree that lowering external pressure to negative gives a suction force and corresponding tension in the piston of T =∆pA.
Then, the question is: Is not step 3 identical to step 1?
And here are some screenshots from Openfoam:
So, Why is there no axial force in the rod when pressure is applied from inside? The rod will fracture. Do you have an idea about why?
Any ideas and/or suggestions are appreciated!
Itek is offline   Reply With Quote
Old   May 30, 2014, 03:40
Kjetil
I hope I posted in correct subforum?
Old   June 3, 2014, 09:30
Kjetil
Bump......
Old   June 6, 2014, 04:52
Kjetil
No ideas? no opinions?
Masters CFD Thesis in Aerodynamics VJ0085 Main CFD Forum 3 July 7, 2013 07:58
master's thesis topic suggestion kamyar Main CFD Forum 0 April 22, 2013 05:20
Dr.Kurul's Thesis request CFDtoy Main CFD Forum 2 October 4, 2011 09:32
any body is having PhD thesis on combustion han Main CFD Forum 2 November 14, 2005 05:03
Thesis writing Srinivas Main CFD Forum 1 September 12, 2002 07:39
