Fan in OpenFOAM 2.3.0
Old   April 23, 2014, 02:35
Default Fan in OpenFOAM 2.3.0
Puglin is on a distinguished road
Hi all,
I'm endeavouring to simulate the flow through a duct (with simpleFoam). The duct has a fan pulling air through it, which I'm trying to simulate with a cyclic-type fan. At this stage I'm content with doing so in a 2D context. I used Gmesh to build the duct cross section and extrude it (adding a planar surface to serve as my fan patch).
My first mistake was using a setup for the boundary and 0 files I found in an old tutorial that ceased to be relevant when version 2.0 changed the way you set up cyclic patches; when I went to run the simulation it asked if I wanted to run foamUpgradeCyclics, to automatically convert my files to the new form. I did that, and it altered my boundary file and all the files in 0, saving backups of the old ones. So far so good.
However, when I went to run the simulation, I got a fatal error:
Reading field p
--> FOAM FATAL ERROR:
request for surfaceScalarField phi from objectRegistry region0 failed
available objects of type surfaceScalarField are
0()
From function objectRegistry::lookupObject<Type>(const word&) const
in file /home/opencfd/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 198.
FOAM aborting
I endeavoured to access p to see what was wrong, but when I tried to open it with gedit, gedit was unable to detect the character encoding. I have no idea what foamUpgradeCyclics did to this file (all the other ones it edited open just fine); is this normal?
Is there some way I can edit the (thankfully backed up) old p file to reflect the new nature of the cyclic system? This is how the old (obsolete) p looks:
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type freestreamPressure;
exit
Fan
type fan;
patchType cyclic;
f List<scalar> 2 (10.0 -1.0);
value uniform 0;
top
bottom
ForeDuct
type zeroGradient;
RearDuct
type zeroGradient;
front
type empty;
back
type empty;
I guess the question becomes, how on earth do fans work in 2.x?
Puglin is offline   Reply With Quote
Old   April 25, 2014, 03:58
Nobody has any ideas?
Surely someone must've had cause to implement some kind of pressure gradient in the latest version of openFOAM. Is there any documentation I can consult...? Any more information I can provide...?
Old   June 7, 2014, 22:57
Wai Phyo Kyaw
Wai Phyo Kyaw is on a distinguished road
Dear Puglin,
I am a beginner for OF, but I think I made a little modification to fan tutorial. In
0/p, 0/u, 0/k and 0/epsilon, and in the system/fvSchemes too. It worked for me. but I am afraid I have no idea it is right or wrong. Anyway I attached the modified zips. hOpe it will work for you too.
Wai Phyo Kyaw is offline   Reply With Quote
Old   July 7, 2014, 16:35
thg
Thorsten Grahs
thg is on a distinguished road
Dear Puglin,
you find the use of the fan b.c for 2.3 f.i. in the tutorial
./incompressible/pimpleFoam/TJunctionFan
where one have in 0/p
cyclicFaces_master
type fan;
patchType cyclic;
jump uniform 0;
value uniform 0;
jumpTable polynomial
1((100 0));
Like everin in OpenFOAm if you want to understand the stuff, you have to dig deeper...
fan b.c.
./finiteVolume/fields/fvPatchFields/derived/fan
in fanFvPatchFields.C
you find the evaluation of the polynomial/list.
The code state that the old format works, but I have not checked this.
if you want to know, how the polynomial is defined you have to ckeck
$FOAM_SRC/OpenFOAM/primitives/functions/DataEntryolynomial/
in "polynomial.C" f.i.
Foam::scalar Foam:olynomial::value(const scalar x) const
scalar y = 0.0;
forAll(coeffs_, i)
y += coeffs_[i].first()*pow(x, coeffs_[i].second());
return y;
thg is offline   Reply With Quote
[OpenFOAM.org] openfoam 2.2.x - mesquite 2.3.0 joegi.geo OpenFOAM Installation 3 February 27, 2017 10:20
Interpreting streamlines of a rotating fan. danbence Visualization & Post-Processing 1 April 8, 2014 10:13
OpenFOAM Foundation releases OpenFOAM 2.2.2 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 October 14, 2013 07:18
ESI-OpenCFD Releases OpenFOAM v2.2.0 opencfd OpenFOAM Announcements from ESI-OpenCFD 13 March 30, 2013 16:52
Propeller Fan Curve Simulation Teng_YJ FLUENT 2 February 16, 2009 19:37
