Problem with creation of new BC fixing it to a patch using refCast
Old   April 26, 2014, 10:44
Default Problem with creation of new BC fixing it to a patch using refCast
Matt_B is on a distinguished road
Hi guys,
I already opened a post talking about my problems in setting a new BC to a patch, using refCast method; the post is located here: http://www.cfd-online.com/Forums/ope...m-refcast.html
I did some new steps further, but now I have troubles to compile the library.
As I explained in the previous post, I thought the possible solution to the problem of lack in identification of my new Boundary Condition also as a new type to be used by refCast method, could be in the macros written at the end of fvPatchField.H.
Therefore I tried to use these macros in some ways, taking inspiration by reading other already compiled BCs. I looked at calculatedFvPatchField as an example and I tried to reproduce same code arrangement; in 'calculated' folder I find the following headers:
calculatedFvPatchField.C
calculatedFvPatchField.H
calculatedFvPatchFields.C
calculatedFvPatchFields.H
calculatedFvPatchFieldsFwd.H
I did the same for my headers:
myGradientEnthalpyFvPatchScalarField.C
myGradientEnthalpyFvPatchScalarField.H
myGradientEnthalpyFvPatchScalarFields.C
myGradientEnthalpyFvPatchScalarFields.H
myGradientEnthalpyFvPatchScalarFieldsFwd.H
The content of the headers in which are called the macros are the following:
namespace Foam
// * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * //
makePatchTypeField
    fvPatchScalarField,
} // End namespace Foam
#ifndef myGradientEnthalpyFvPatchFields_H
#define myGradientEnthalpyFvPatchFields_H
#include "myGradientEnthalpyFvPatchScalarField.H"
#include "fieldTypes.H"
namespace Foam
template<class Scalar> class myGradientEnthalpyFvPatchField;
makePatchTypeFieldTypedefs(myGradientEnthalpy);
#endif
#ifndef myGradientEnthalpyFvPatchFieldsFwd_H
#define myGradientEnthalpyFvPatchFieldsFwd_H
namespace Foam
#endif
The error that comes out after making an attempt to compile the library is as here attached:
Making dependency list for source file myGradientEnthalpyFvPatchScalarField/myGradientEnthalpyFvPatchScalarFields.C
SOURCE=myGradientEnthalpyFvPatchScalarField/myGradientEnthalpyFvPatchScalarFields.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O0 -fdefault-inline -ggdb3 -DFULLDEBUG -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.1.1/src/meshTools/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels/compressible/turbulenceModel/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels/compressible/matteoBC/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/basic/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/basicSolidThermo/lnInclude  -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPDebug/myGradientEnthalpyFvPatchScalarFields.o
In file included from /opt/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/Field.H:360:0,
                 from /opt/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/labelField.H:39,
                 from /opt/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/primitiveFields.H:37,
                 from /opt/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/pointField.H:36,
                 from /opt/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/edge.H:40,
                 from /opt/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/edgeList.H:32,
                 from /opt/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/PrimitivePatch.H:56,
                 from /opt/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/primitivePatch.H:35,
                 from /opt/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/polyPatch.H:43,
                 from /opt/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude/fvPatch.H:39,
                 from /opt/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude/fvPatchField.H:47,
                 from /opt/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude/fixedGradientFvPatchField.H:38,
                 from /opt/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude/fixedGradientFvPatchFields.H:29,
                 from /opt/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/basic/lnInclude/gradientEnthalpyFvPatchScalarField.H:38,
                 from myGradientEnthalpyFvPatchScalarField/myGradientEnthalpyFvPatchScalarField.H:52,
                 from myGradientEnthalpyFvPatchScalarField/myGradientEnthalpyFvPatchScalarFields.H:29,
                 from myGradientEnthalpyFvPatchScalarField/myGradientEnthalpyFvPatchScalarFields.C:26:
/opt/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/Field.C: In member function ‘void Foam::Field<Type>::operator=(const Foam::VectorSpace<Form, Cmpt, nCmpt>&)’:
/opt/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/Field.C:680:42: warning: typedef ‘VSType’ locally defined but not used [-Wunused-local-typedefs]
     typedef VectorSpace<Form,Cmpt,nCmpt> VSType;
In file included from /opt/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude/fixedGradientFvPatchField.H:38:0,
myGradientEnthalpyFvPatchScalarField/myGradientEnthalpyFvPatchScalarFields.H: At global scope:
myGradientEnthalpyFvPatchScalarField/myGradientEnthalpyFvPatchScalarFields.H:43:28: error: conflicting declaration ‘typedef class Foam::myGradientEnthalpyFvPatchField<double> Foam::myGradientEnthalpyFvPatchScalarField’
/opt/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude/fvPatchField.H:597:40: note: in definition of macro ‘makePatchTypeFieldTypedefs’
     typedef type##FvPatchField<scalar> type##FvPatchScalarField;              \
In file included from myGradientEnthalpyFvPatchScalarField/myGradientEnthalpyFvPatchScalarFields.H:29:0,
myGradientEnthalpyFvPatchScalarField/myGradientEnthalpyFvPatchScalarField.H:66:7: error: ‘class Foam::myGradientEnthalpyFvPatchScalarField’ has a previous declaration as ‘class Foam::myGradientEnthalpyFvPatchScalarField’
 class myGradientEnthalpyFvPatchScalarField
make: *** [Make/linux64GccDPDebug/myGradientEnthalpyFvPatchScalarFields.o] Error 1
I'm sure I didn't use in a proper way the macros supplied by openFoam.
Could someone tell me how to do it better?
Thank you all.
Matteo
Matt_B is offline   Reply With Quote
refcast, typedef
[Other] Cyclic patch problem! SMartella OpenFOAM Meshing & Mesh Conversion 6 July 26, 2023 16:00
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
problem with surface creation in ICEM from multiple curves dialolema ANSYS Meshing & Geometry 2 October 27, 2014 13:14
[Gmsh] Single volume Mesh gmsh PeteH OpenFOAM Meshing & Mesh Conversion 9 August 6, 2013 08:54
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
