Flow around two tandem cylinders
Old   May 29, 2014, 07:56
Default Flow around two tandem cylinders
Shantanu Kale
shantanukale is on a distinguished road
Hello...
I am trying to simulate flow around two tandem circular cylinders. I am not able to replicate the results as reported in literature. The results are in well confirmation with the literature when spacing between the cylinders is increased. However, with the same case setup, I am unable to obtain results for less spacing (say spacing between cylinders is 2).
The flow is having a Reynolds number of 100.
Solver used is pisoFoam.
Simulation is 2D and laminar. The schemes being used are linear schemes.
Kindly suggest some measures.
Thank You.
shantanukale is offline   Reply With Quote
Old   May 30, 2014, 04:24
T. Chourushi
Tushar@cfd is on a distinguished road
Originally Posted by shantanukale View Post
Hello...
Thank You.
Have you checked the mesh dimensions for both the cases?
Can you post comparison plot for your result here?
Tushar@cfd is offline   Reply With Quote
Old   May 30, 2014, 05:47
Akshay Kumar
Akshay is on a distinguished road
Hey
Could you post some of your results? Maybe a line plot (velocity ...etc.) ...
Akshay is offline   Reply With Quote
Old   May 30, 2014, 07:32
Shantanu Kale
Thank you for your kind reply..
May I know which results should I post? I mean the velocity, pressure colour plots or cl, cd, cp plots?
TD P { margin-bottom: 0cm; direction: ltr; color: rgb(0, 0, 0); }TD P.western { }TD P.cjk { }TD P.ctl { }P { margin-bottom: 0.21cm; direction: ltr; color: rgb(0, 0, 0); }P.western { }P.cjk { }P.ctl {*
Old   May 30, 2014, 08:19
Akshay Kumar
Hey
Could you share the mesh (an image) and maybe the contour plots of velocity & pressure? (For both simulations)
Old   May 30, 2014, 09:00
T. Chourushi
What do you mean by this line..
Which result you are talking about that you should mention with comparison plot. Otherwise it is difficult to guess what you are comparing.
Define area and depth for drag coefficient calculation for flow over of cylinders engr FLUENT 5 May 26, 2023 05:22
Different flow patterns in CFX and Fluent avi@lpsc FLUENT 4 April 8, 2012 06:12
PROBLEMS WITH ROTATING FLOW BETWEEN TWO CYLINDERS vitmalin CFX 2 October 11, 2006 07:22
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 05:18
