Solver for spray atomization and breakup (without combustion)? |
June 4, 2014, 11:06 |
Sebastian
Rep Power: 12 |
Hello cfd-online community,
I am currently looking for a solver to simulate atomization and breakup of a jet. In the OpenFOAM-Folder I found models for atomization and breakup in OpenFOAM-2.3.x/src/lagrangian/spray/submodels. My question is: What solver type is supposed to be used with theese submodels? Is sprayFoam the one that should be used? The only tutorial case I have found for this one is aachenBomb. But that includes combustion as well. Is it possible to run it without combustion? Do you know any other tutorial cases that can be found somewhere in the www? I would so much appreciate your help. I am new to OpenFoam and have always found good help in this Forum. Thank you |
June 5, 2014, 17:00 |
Hi Sebastian,
This thread may related to your question: http://www.cfd-online.com/Forums/ope...ombustion.html Best regards, Likun |
June 10, 2014, 03:47 |
Sebastian
Rep Power: 12 |
Hey Likun,
thank you very much for your reply. It seems that sprayFoam is the way to go here. I will turn chemistry off and combustion to active false and try things out. I've found some presentations and links in the internet and will dig around in the literature and cfd-online threads. I will let you know how the spray simulation went. If you have any further suggestions or literature about modelling sprays with OF, I will highly appreciate it. Thank you very much! |
November 13, 2014, 14:47 |
saeed
Rep Power: 12 |
I have your problem too (solvers for spray atomization without combustion). have you found any solution for this problem at this time (from June to present)? I will appreciate if you help me. With respectSaeed |
Atomization and Breakup model | xck1986 | OpenFOAM | 4 | May 31, 2014 04:43 |
Problem in breakup and atomization Model | daniel87 | OpenFOAM | 0 | July 11, 2013 05:53 |
breakup phenomena atomization | manuels | FLUENT | 0 | July 23, 2012 03:45 |
the role of the atomization model | Jay | Siemens | 2 | March 7, 2008 20:16 |
atomization model vs breakup model | Jay | Siemens | 7 | January 24, 2008 19:51 |
