July 14, 2014, 07:42 |
buoyantSimpleFoam + porous zone
Rep Power: 11 |
is it possible to model porous zone with buoyantSimpleFoam or bouyantPimpleFoam? I have tried to add the porous zone into fvOptions but the solver failed (I think) due to messing thermodynamic properties of the porous zone. Can somebody advise me please how to implement this? Thanks |
July 14, 2014, 11:09 |
hi atlan,
I tried it before by modifying the buoyantBoussinesqSimpleFoam but I gave up. and still I wanna do it, if my works let me do that! what's the error? did u make the solver correctly? Regards, Mostafa |
July 16, 2014, 09:48 |
Rep Power: 11 |
Hi Mostafa,
Thank you for the answer. I have not made any solver, which is probably the problem. Is there any solver which is applicable for the calculation of heat transfer (wall conduction) including the porous wall? Regards |
July 16, 2014, 09:53 |
AFAIK, nope, there isn't such a solver.
you should add energy equation for clear fluid and porous zone yourself. |
July 20, 2014, 09:03 |
Joachim Herb
Rep Power: 21 |
I am not sure, that I understand what you want to do, but I used the following fvOptions successfully with buoyantPimpleFoam:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvOptions; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // porosityBlockage { type explicitPorositySource; active off; selectionMode cellZone; cellZone porous; explicitPorositySourceCoeffs { type DarcyForchheimer; DarcyForchheimerCoeffs { d d [0 -2 0 0 0] (1e9 1e9 0); f f [0 -1 0 0 0] (1e9 1e9 0); coordinateSystem { e1 (1 0 0); e2 (0 1 0); } } } } // ************************************************************************* // |
July 24, 2014, 03:33 |
Porous zone + BuoyantSimpleFoam - SOLVED
Rep Power: 11 |
Thank you,
This really works. In fvOptions you can also add the porous zone temperature. Atlan |
April 25, 2017, 13:05 |
alberto
Rep Power: 10 |
I'm trying to run buoyantSimpleFoam with a porous media fvoptions like you said and then stop, giving the following message:
Could you help me, or give me an advice please |
May 3, 2017, 13:37 |
alberto
Rep Power: 10 |
Hello., im trying to simulate a pipe with porous media and heat transfer using buoyant simplefoam with fvoptions porousmedia.
Do you know why the simulation stop? I dont understand what mean that error. thank u for your time Time = 26 DILUPBiCG: Solving for Ux, Initial residual = 0.0623969, Final residual = 0.000334212, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.101444, Final residual = 0.000653273, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.149451, Final residual = 0.000506783, No Iterations 1 DILUPBiCG: Solving for h, Initial residual = 0.00689413, Final residual = 1.16579e-05, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 0.14369, Final residual = 0.00132583, No Iterations 4 time step continuity errors : sum local = 0.0131216, global = 0.00379873, cumulative = 0.00339527 rho max/min : 2.66735 0.225983 ExecutionTime = 336.84 s ClockTime = 389 s Time = 27 DILUPBiCG: Solving for Ux, Initial residual = 0.0921637, Final residual = 0.000623586, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.12727, Final residual = 0.00119562, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.277155, Final residual = 0.00148346, No Iterations 1 DILUPBiCG: Solving for h, Initial residual = 0.00678693, Final residual = 6.33452e-06, No Iterations 2 [0] #0 Foam::error:rintStack(Foam::Ostream&) at ??:? [0] #1 Foam::sigFpe::sigHandler(int) at ??:? [0] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [0] #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:? [0] #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? [0] #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? [0] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? [0] #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? [0] #8 Foam::fvMatrix<double>::solve() at ??:? [0] #9 ? at ??:? [0] #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [0] #11 ? at ??:? [Guacamaya:09486] *** Process received signal *** [Guacamaya:09486] Signal: Floating point exception (8) [Guacamaya:09486] Signal code: (-6) [Guacamaya:09486] Failing at address: 0x3e80000250e [Guacamaya:09486] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f0ff0dce4b0] [Guacamaya:09486] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7f0ff0dce428] [Guacamaya:09486] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f0ff0dce4b0] [Guacamaya:09486] [ 3] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5scaleERNS_5Fi eldIdEES3_RKNS_9lduMatrixERKNS_10FieldFieldIS1_dEE RKNS_8UPtrListIKNS_17lduInterfaceFieldEEERKS2_h+0x ce)[0x7f0ff2039b4e] [Guacamaya:09486] [ 4] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7 PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS 8_S9_S9_S9_S9_S9_RNS1_IS8_EESD_h+0x7b2)[0x7f0ff203ddb2] [Guacamaya:09486] [ 5] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5Fi eldIdEERKS2_h+0x86d)[0x7f0ff204070d] [Guacamaya:09486] [ 6] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegr egatedERKNS_10dictionaryE+0x15b)[0x7f0ff5a5f95b] [Guacamaya:09486] [ 7] buoyantSimpleFoam(_ZN4Foam8fvMatrixIdE5solveERKNS_ 10dictionaryE+0x191)[0x493971] [Guacamaya:09486] [ 8] buoyantSimpleFoam(_ZN4Foam8fvMatrixIdE5solveEv+0x1 35)[0x493c25] [Guacamaya:09486] [ 9] buoyantSimpleFoam[0x4306bc] [Guacamaya:09486] [10] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f0ff0db9830] [Guacamaya:09486] [11] buoyantSimpleFoam[0x433539] [Guacamaya:09486] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 0 with PID 9486 on node Guacamaya exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- |
Modelling Combustion in Porous Zone | tanjinjack | FLUENT | 2 | September 26, 2016 04:10 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 01:08 |
