Can I use fvOptions to couple a solid region and a fluid region?
Old   July 24, 2014, 13:36
Default Can I use fvOptions to couple a solid region and a fluid region?
CZ
titanchao is on a distinguished road
The solid region represents a porous medium. The reason I want to do the coupling is because I need to solve both the thermal energy transport in the fluid and the heat conduction in the porous medium. I intend to use the chtMultiRegionSimpleFoam solver.
(1) Is fvOptions allowed to be used to couple two regions that have different governing equations?
(2) I modified the settings based on the heat exchanger case in the tutorial. Because I want a heat conduction equation to be solved for my porous region (vs. another flow region in the original tutorial case), I modified the fvSchems file to one that's supposed to solve a Laplacian equation only (see the following). Is this correct?
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSchemes;
ddtSchemes
default steadyState;//Euler;
gradSchemes
default Gauss linear;
grad(T) Gauss linear;
divSchemes
default none;
laplacianSchemes
default none;
laplacian(K,T) Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
T ;
(3) Why does it keep asking for a pressure initial condition for the porous media (solid) region? If it only solves a heat conduction equation, why is pressure field needed?
chao@ChaoCFDLinux:~/OpenFOAM/chao-2.3.0/run/oneChannePorousMediaHT$ chtMultiRegionSimpleFoam
| \\ / O peration | Version: 2.3.0 |
| \\/ M anipulation | |
Build : 2.3.0-f5222ca19ce6
Exec : chtMultiRegionSimpleFoam
Date : Jul 24 2014
Time : 09:52:16
Host : "ChaoCFDLinux"
PID : 13319
Case : /home/chao/OpenFOAM/chao-2.3.0/run/oneChannePorousMediaHT
nProcs : 1
Create time
Create fluid mesh for region domainFluid for time = 0
Create solid mesh for region exRegionSolid for time = 0
*** Reading fluid mesh thermophysical properties for region domainFluid
Adding to thermoFluid
Selecting thermodynamics package
type heRhoThermo;
mixture pureMixture;
transport const;
thermo hConst;
equationOfState rhoConst;
specie specie;
energy sensibleEnthalpy;
Adding to rhoFluid
Adding to UFluid
Adding to phiFluid
Adding to gFluid
Adding to turbulence
Selecting turbulence model type laminar
Adding to ghFluid
Adding to ghfFluid
Selecting radiationModel none
Adding fvOptions
Creating finite volume options from fvOptions
Selecting finite volume options model type constantHeatTransfer
Source: fluidTosolid
- applying source for all time
- selecting inter region mapping
Creating mesh-to-mesh addressing for domainFluid and exRegionSolid regions using cellVolumeWeight
Overlap volume: 1.10097e-05
Selecting finite volume options model type interRegionExplicitPorositySource
Source: porosityBlockage
*** Reading solid mesh thermophysical properties for region exRegionSolid
Adding to thermos
type heSolidThermo;
transport constIso;
thermo hConst;
specie specie;
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/chao/OpenFOAM/chao-2.3.0/run/oneChannePorousMediaHT/0/exRegionSolid/p at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
(4) It appears the fvOptions has to be defined respectively for both regions, the fluid and the porous region (solid). Does it matter which one is the master region?
(5) Anyone has solved similar problems? And other suggestions to solve the problem?
Thank you so much!
titanchao is offline   Reply With Quote
Old   March 7, 2018, 07:46
Adri
Adri_12 is on a distinguished road
Hi, titanchao
Did you have any answers to your problems ?
Thanks for your help !
Adrià
Adri_12 is offline   Reply With Quote
Old   November 21, 2020, 17:13
Utkan Erdem
Utkan is on a distinguished road
I'm curious about the exact same problem, how to couple the porous region to air in this case? Anyone?
Utkan is offline   Reply With Quote
Old   July 1, 2021, 13:22
sw choi
choist31 is on a distinguished road
The key thing is porous media should be defined as fluid since it calculates the momentum(Pressure) sink. Thus, porous media can't be defined in solid region method even though code does not show any error or warning message (When you try to see the heat transfer and velocity in solid porous region, no effect is found). Please refer to chtMultiRegionSimple foam tutorial case; heat exchanger. I've make a lot of effort to add the porous features for 2DSolidQuenching tutorial case.
choist31 is offline   Reply With Quote
Old   January 14, 2022, 07:55
Default Metal foam as porous media in openfoam
shubham mishra
mishrashubham is on a distinguished road
Did any body solve above problem. How to use metal foam as a porous media?
mishrashubham is offline   Reply With Quote
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 14:26
chtMultiRegionSimpleFoam samiam1000 OpenFOAM Running, Solving & CFD 39 March 31, 2016 08:43
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
