Simulation of rotoating objects using OpenFOAM |
August 8, 2014, 06:50 |
Abhijit
Rep Power: 11 |
HI everyone
Is it possible to simulate flow over rotating objects like cylinder/compressor fans using openfoam version2.2.2 . If so can someone please provide me with some useful material to read so that i can understand and simulate the rotating case. Thanks. |
August 8, 2014, 11:14 |
Michael D.
Rep Power: 11 |
Hi Jetfire,
I'm not an expert on OpenFOAM or simulating rotating objects, but is it something like this you are looking for? http://www.slideee.com/slide/cfd-for...using-openfoam There should also be some tutorials on the rotating reference frame solvers (e.g. SRFSimpleFoam) in OpenFOAM that you can use to get started. |
August 8, 2014, 13:36 |
Abhijit
Rep Power: 11 |
@Michael
ya it's the same thing i am looking for , il go through the slides and tutorials based on rotating reference frame. Thank you very much. |
August 8, 2014, 14:14 |
Michael D.
Rep Power: 11 |
Glad I could be of help, and good luck!
error to check simulation result: could not find valid OpenFOAM mesh | xiaoyoyo | OpenFOAM | 5 | May 18, 2017 11:38 |
Wave simulation using OpenFoam | Ellie | OpenFOAM | 2 | August 30, 2013 02:10 |
diesel Engine simulation in OpenFOAM | karam | OpenFOAM Running, Solving & CFD | 1 | March 1, 2011 09:46 |
Salome and Code Saturne simulation of simple room and objects | cristian.ocnarescu | Main CFD Forum | 0 | June 21, 2010 10:19 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
