October 6, 2014, 11:51 |
Where to find information on dictionaries
Mattia Tamellini
Rep Power: 12 |
Hi everyone!
I hope I chose the right section to post to. I was wondering where I could find some information on the various dictionaries used by OpenFOAM. I feel that the documentation is somewhat lacking in this sense: when I need to use something that is not covered in the user guide, where can I find information about it? I know there are the tutorials too, but the various utilites are only used and never explained or commented upon. More precisely, I am currently trying to solve a multiphase moving mesh case similar to the one shown in the interDyMFoam/DTCHull tutorial, but I am finding it difficult to proper set up the dictionary since I don't know where to find some kind of list with all the possible entries for the dynamicMeshDict and their meaning. Also the wiki page (http://openfoamwiki.net/index.php/Ma...m#Dynamic_Mesh) was not helpful, since it is too concise. Can you please point me to some references where the less basic OpenFOAM utilities are explained? Thanks in advance |
October 6, 2014, 12:22 |
Vito Fasano
Rep Power: 12 |
Hi Mattia,
if I understand what you are searching, in the installation directory of OpenFOAM there are all dictionaries with all commands that you can use. If you do a search in the directory, for example "controlDict", you'll find a file called "controlDict" with all the commands that you can use. Copy it in your simulation's directory and modify it |
October 7, 2014, 04:23 |
Mattia Tamellini
Rep Power: 12 |
Hello Vito,
thanks a lot for the reply! I am not sure I understand what you mean though. If I search for "dynamicMeshDict" in my OpenFOAM installation folder, this is what I get: Code:
mattia@replicant:~$ of230 mattia@replicant:~$ cd $WM_PROJECT_DIR mattia@replicant:OpenFOAM-2.3.0$ pwd /home/mattia/OpenFOAM/OpenFOAM-2.3.0 mattia@replicant:OpenFOAM-2.3.0$ find . -name "dynamicMeshDict" ./tutorials/combustion/PDRFoam/flamePropagationWithObstacles/constant/dynamicMeshDict ./tutorials/multiphase/interFoam/laminar/damBreak/constant/dynamicMeshDict ./tutorials/multiphase/LTSInterFoam/DTCHull/constant/dynamicMeshDict ./tutorials/multiphase/interDyMFoam/ras/mixerVesselAMI/constant/dynamicMeshDict ./tutorials/multiphase/interDyMFoam/ras/sloshingTank3D/constant/dynamicMeshDict ./tutorials/multiphase/interDyMFoam/ras/sloshingTank3D6DoF/constant/dynamicMeshDict ./tutorials/multiphase/interDyMFoam/ras/testTubeMixer/constant/dynamicMeshDict ./tutorials/multiphase/interDyMFoam/ras/sloshingTank2D3DoF/constant/dynamicMeshDict ./tutorials/multiphase/interDyMFoam/ras/damBreakWithObstacle/constant/dynamicMeshDict ./tutorials/multiphase/interDyMFoam/ras/sloshingTank2D/constant/dynamicMeshDict ./tutorials/multiphase/interDyMFoam/ras/sloshingTank3D3DoF/constant/dynamicMeshDict ./tutorials/multiphase/interDyMFoam/ras/floatingObject/constant/dynamicMeshDict ./tutorials/multiphase/interDyMFoam/ras/DTCHull/constant/dynamicMeshDict ./tutorials/multiphase/compressibleInterDyMFoam/ras/sloshingTank2D/constant/dynamicMeshDict ./tutorials/multiphase/interPhaseChangeDyMFoam/propeller/constant/dynamicMeshDict ./tutorials/multiphase/interMixingFoam/laminar/damBreak/constant/dynamicMeshDict ./tutorials/mesh/moveDynamicMesh/SnakeRiverCanyon/constant/dynamicMeshDict ./tutorials/mesh/foamyHexMesh/mixerVessel/constant/dynamicMeshDict ./tutorials/incompressible/pimpleDyMFoam/propeller/constant/dynamicMeshDict ./tutorials/incompressible/pimpleDyMFoam/mixerVesselAMI2D/constant/dynamicMeshDict ./tutorials/incompressible/pimpleDyMFoam/wingMotion/wingMotion2D_pimpleDyMFoam/constant/dynamicMeshDict ./tutorials/incompressible/pimpleDyMFoam/oscillatingInletACMI2D/constant/dynamicMeshDict ./tutorials/incompressible/pimpleDyMFoam/movingCone/constant/dynamicMeshDict ./tutorials/compressible/rhoPimpleDyMFoam/annularThermalMixer/constant/dynamicMeshDict ./src/dynamicFvMesh/dynamicRefineFvMesh/dynamicMeshDict mattia@replicant:OpenFOAM-2.3.0$ Code:
mattia@replicant:dynamicRefineFvMesh$ cat dynamicMeshDict /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object dynamicMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // //dynamicFvMeshLib "libtopoChangerFvMesh.so"; dynamicFvMesh dynamicRefineFvMesh; //staticFvMesh; mixerFvMeshCoeffs { coordinateSystem { type cylindrical; origin (0 0 0); axis (0 0 1); direction (1 0 0); } rpm 10; slider { inside insideSlider; outside outsideSlider; } } // Refinement dynamicRefineFvMeshCoeffs { // Refine every refineInterval timesteps refineInterval 3; // Maximum refinement level (starts from 0) maxRefinement 2; // Maximum cell limit (approximate) maxCells 1000000; // volScalarField to base refinement on field gamma; // Which cells to un/refine: based on point values (simple averaging). // - refine pointCells of point value inbetween minLevel..maxLevel // - unrefine pointCells that are within nBufferLayers of points marked // for refinement. minLevel 0.01; maxLevel 0.99; nBufferLayers 1; // Newly introduced patch points optionally get projected onto a surface //projectSurfaces ("fixedWalls4.stl"); //projectPatches (fixedWalls); // Maximum project distance //projectDistance 1; // Fluxes to adapt. For newly created faces or split faces the flux // gets estimated from an interpolated volVectorField ('velocity') // First is name of the flux to adapt, second is velocity that will // be interpolated and inner-producted with the face area vector. correctFluxes ((phi U)); } // ************************************************************************* // mattia@replicant:dynamicRefineFvMesh$ Thanks again for your help |
October 7, 2014, 09:05 |
Vito Fasano
Rep Power: 12 |
You understand right, but it is strange there is not a general dynamicMeshDict file that contains the possible commands..I'll try to look on my computer and I'lltell you
October 8, 2014, 05:06 |
Mattia Tamellini
Rep Power: 12 |
Ok, I'll wait for your reply! Thanks a lot
documentation, dynamic mesh |
ERROR: unable to find library | HJH | CFX | 6 | February 26, 2019 06:52 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
interchanging face information with cell information/ radiation flux UDF | ximik | FLUENT | 1 | May 4, 2011 16:34 |
where can I find the information about "common block"? | mactonald | Siemens | 5 | June 15, 2009 01:46 |
where can I find the information about all the common block? | mactonald | STAR-CD | 0 | May 31, 2009 04:49 |
