twoPhaseEulerFoam, abnormally high velocities cause stability issues |
April 14, 2015, 13:07 |
Luis BL
Hello all,
I am trying to simulate a bench size fluidized bed with immersed cylinders. The domain is 2D, the overall dimensions are 58x26 cm. I attached an image with the domain visualized in paraview. I created the mesh with gmesh and used the gmshtofoam utility, which worked without a problem. There are two phases a solid and gas. Gas inlet velocity is set to 13 cm/s. The case runs well for a very coarse mesh (up to ~60s which is what I need), however for the finer mesh that I need to use, the simulation crashes around 15 seconds in. The results show abnormally high gas and solid velocities (>40m/s) in a region near the outlet (top of the domain). I have tried different time discretization schemes but nothing seems to work. Has anyone encountered a similar issue? or has any ideas on what could be causing the issue? Thanks, Luis |
twophaseeulerfoam |
having some issues in Wake Stability using UVLM for propellers | jackgeo | Main CFD Forum | 1 | November 26, 2014 05:05 |
Multigrid Stability Issues | ThomasHermann | SU2 | 1 | November 5, 2014 16:18 |
Convergence Stability Issues | ts_swati | Fluent Multiphase | 0 | July 7, 2014 21:11 |
HIgh viscosity - convergence issues | manxu | FLUENT | 0 | February 12, 2014 08:57 |
Numerical stability issues | poornima | Main CFD Forum | 2 | June 7, 2006 11:04 |
