Error - buoyantBoussinesqSimpleFoam Solver
Old   October 22, 2014, 14:06
Default Error - buoyantBoussinesqSimpleFoam Solver
usask is on a distinguished road
Hi!
I am new to OpenFOAM and I don't know how to resolve this problem: (I did the mesh in Salome).
Time = 3
DILUPBiCG: Solving for Ux, Initial residual = 0.586599, Final residual = 0.00342578, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.123037, Final residual = 0.000729083, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 0.715719, Final residual = 0.00748276, No Iterations 2
DILUPBiCG: Solving for T, Initial residual = 1.84479e-08, Final residual = 1.84479e-08, No Iterations 0
DICPCG: Solving for p_rgh, Initial residual = 0.999996, Final residual = 475.492, No Iterations 1001
time step continuity errors : sum local = 3.16764e+17, global = -8.23715e+13, cumulative = -8.23715e+13
DILUPBiCG: Solving for epsilon, Initial residual = 1, Final residual = 0.040937, No Iterations 21
DILUPBiCG: Solving for k, Initial residual = 0.00305874, Final residual = 1.17067e-08, No Iterations 1
bounding k, min: -3183.13 max: 1.51602e+26 average: 1.03354e+21
ExecutionTime = 30 s ClockTime = 30 s
Time = 4
DILUPBiCG: Solving for Ux, Initial residual = 4.73418e-05, Final residual = 9.99871e-06, No Iterations 7
DILUPBiCG: Solving for Uy, Initial residual = 6.06685e-06, Final residual = 6.06685e-06, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 6.1559e-06, Final residual = 6.1559e-06, No Iterations 0
DILUPBiCG: Solving for T, Initial residual = 4.68967e-08, Final residual = 4.68967e-08, No Iterations 0
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:?
#4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
at ??:?
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
Floating point exception (core dumped)
Thanks.
usask is offline   Reply With Quote
Old   October 22, 2014, 15:50
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
there's not much information about your case, so according to
it's diverging.
To answer you question "why it's diverging?", one needs to know a little bit more about your case: checkMesh output, initial conditions, boundary conditions.
alexeym is offline   Reply With Quote
Old   October 23, 2014, 02:04
tian's Avatar
Tian
tian is on a distinguished road
it seems you have a boundary condition problem. Look to your p iteration... more than 1001.
Bye
Thomas
BIM HVACTool, The Green Building Simulation Tool for OpenFOAM, Energy Plus and Radiance.
tian is offline   Reply With Quote
Old   October 23, 2014, 14:06
Hi!
Thanks for your replies.
Here's the output from checkMesh:
| \\ / O peration | Version: 2.3.0 |
| \\/ M anipulation | |
Build : 2.3.0-f5222ca19ce6
Exec : checkMesh
Date : Oct 23 2014
Time : 12:01:17
Host : "psci-ThinkPad-T440s"
PID : 3751
Case : /home/psci/OpenFOAM/psci-2.3.0/run/barn_4pigs_22Oct
nProcs : 1
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
faces: 489678
internal faces: 478946
cells: 242156
faces per cell: 4
boundary patches: 9
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 0
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 242156
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
*Number of regions: 5
The mesh has multiple regions which are not connected by any face.
<<Writing region information to "0/cellToRegion"
<<Writing region 0 with 235940 cells to cellSet region0
<<Writing region 1 with 1398 cells to cellSet region1
<<Writing region 2 with 1587 cells to cellSet region2
<<Writing region 3 with 1567 cells to cellSet region3
<<Writing region 4 with 1664 cells to cellSet region4
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
wall 8057 4104 ok (non-closed singly connected)
inlets 150 145 ok (non-closed singly connected)
fan1 26 21 ok (non-closed singly connected)
fan2 49 35 ok (non-closed singly connected)
fan3 52 37 ok (non-closed singly connected)
pig1 582 293 ok (closed singly connected)
pig2 618 311 ok (closed singly connected)
pig3 570 287 ok (closed singly connected)
pig4 628 316 ok (closed singly connected)
Checking geometry...
Overall domain bounding box (-200 0 0) (19830 6970 3100)
Mesh (non-empty, non-wedge) directions (1 1 1)
Boundary openness (-6.72814e-18 -1.79846e-16 5.96753e-16) OK.
Max cell openness = 2.66659e-16 OK.
Max aspect ratio = 4.59976 OK.
Minimum face area = 1116.39. Maximum face area = 549194. Face area magnitudes OK.
Min volume = 19024.7. Max volume = 1.28777e+08. Total volume = 4.045e+11. Cell volumes OK.
Mesh non-orthogonality Max: 51.359 average: 14.4625
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 0.647568 OK.
Coupled point location match (average 0) OK.
Mesh OK.
End
Old   October 23, 2014, 14:08
Hi Thomas,
Boundary condition for p: (not so sure if I got this right)
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
wall
type zeroGradient;
inlets
type fixedValue;
value uniform 0.05;
fan1
type zeroGradient;
fan2
type zeroGradient;
fan3
type zeroGradient;
pig1
type zeroGradient;
pig2
type zeroGradient;
pig3
type zeroGradient;
pig4
type zeroGradient;
Sorry for the very long message. Thanks again guys...
Old   October 23, 2014, 14:12
tian's Avatar
Tian
wow, you have a big room:
Total volume = 4.045e+11 m³
Show me your p_rgh. This is more important. p normal is like "calculated" for every boundary.
Bye
Thomas
Old   October 24, 2014, 11:45
Yes, it is a very big room.
Here's my p_rgh
FoamFile
version 2.0;
format ascii;
object p_rgh;
boundaryField
wall
type fixedFluxPressure;
rho rhok;
value uniform 0;
inlets
rho rhok;
value uniform 0;
fan1
rho rhok;
value uniform 0;
fan2
rho rhok;
value uniform 0;
fan3
rho rhok;
value uniform 0;
pig1
rho rhok;
value uniform 0;
pig2
rho rhok;
value uniform 0;
pig3
rho rhok;
value uniform 0;
pig4
rho rhok;
value uniform 0;
Also, can I change my p to "calculated" then?
Thanks a lot, Thomas.
Fluent Adjoint Solver? ex10148 FLUENT 16 September 28, 2018 08:11
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
Divergence problem Smaras FLUENT 13 February 21, 2013 05:03
3d vof Smaras FLUENT 2 February 19, 2013 06:58
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
