chtMultiRegionSimpleFoam planeWall2D
Old   December 3, 2014, 04:44
Default chtMultiRegionSimpleFoam planeWall2D
Wien3 is on a distinguished road
Good Morning everyone!
I have studied this tutorial (as I read it was the easiest of this kind of solver) and I learnt quite a few things about it.
For my particular case I want to refrigerate a cube which is inside a pipe (attached_figure1), so I think it could be a first step to modify the planeWall2D model, reducing the length of the "wall" layer from both sides.
I tried first with just only the left part (attached_figure2). I think I have to define a "domain1" with takes into account the new free space. I modified every single file it was related with this change, but when I write ./Allrun no new time folders are created, so I can't see the evolution of temperature in paraFoam.
What can I do to solve this? Which file is wrong?
I post the topoSetDict, and I attached the complete model case.
PHP Code:
actions
// bottomAir
name    bottomAir;
type    cellSet;
action  new;
source  boxToCell;
sourceInfo
box (0 0 0 )(1 0.4 0.1);
name    bottomAir;
type    cellZoneSet;
action  new;
source  setToCellZone;
sourceInfo
set bottomAir;
// leftDomain
name    leftDomain;
type    cellSet;
action  new;
source  boxToCell;
sourceInfo
box (0 0.4 0 )(0.2 0.6 0.1);
name    leftDomain;
type    cellZoneSet;
action  new;
sourceInfo
set leftDomain;
// wall
name    wall;
type    cellSet;
action  new;
source  boxToCell;
sourceInfo
box (0.2 0.4 0 )(1 0.6 0.1);
name    wall;
type    cellZoneSet;
action  new;
sourceInfo
set wall;
// topAir
name    topAir;
type    cellSet;
action  new;
source  boxToCell;
sourceInfo
box (0 0.6 0 )(1 1 0.1);
name    topAir;
type    cellZoneSet;
action  new;
sourceInfo
set topAir;
Thank you in advance!!
File Type: jpg Screenshot from 2014-12-03 10:00:20.jpg (34.5 KB, 9 views)
File Type: jpg Screenshot from 2014-12-03 10:37:57.jpg (35.1 KB, 9 views)
Wien3 is offline   Reply With Quote
Old   December 3, 2014, 06:17
I solved it! The problem was I assigned p_rgh wrongly in the lefDomain ChangeDict.
After some time I achieve to build my model.
A fluid is supossed to entered by the left side and to go out by the opposite one, and, as it has less temperature than the cube, there will be a heat transference.
I have two questions now:
1) it is normal the evolution of the temperature behind the cube (it was assigned gravity=0)??
2) What should I change in my case in order to get my cube cold?? Currently it behaves like a constant heat supply.
I attach my files corrected.
Thanks again!
File Type: jpg Screenshot from 2014-12-03 12:16:15.jpg (34.3 KB, 9 views)
