December 18, 2014, 18:03 |
Problems during a run with rhoPimpleFoam
Narmin
Rep Power: 11 |
Im running a case in rhoPimpleFoam. I have set the initial conditions in 0/file sub directory as follows. Pressure dimensions [1 -1 -2 0 0 0 0]; internalField uniform 101325; and then, I have set the boundary field types to each boundary. For velocity, I have given the inlet, absolute values which is something between 10-20 m/s. My problem is this, after running the case for several iterations, the pressure values reach to abt 1.9e07, which is huge. the thermal field also seems not to be calculated correctly, however the velocities seems to have captured the flow filed. Does anyone know, what could be the problem. Another question is this, I have calculated the case in incompressible solvers correctly (since it is a M<0.1case) but cannot find a suitable way to add the thermal filed to it. I have tried thermoFoam application but was unable to run it. Is there any tutorial to help running with thermoFoam? Thanks |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
First Parallel Run - need some help | Gian Maria | OpenFOAM | 3 | June 17, 2011 12:08 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
[OpenFOAM] Problems with ParaView | alejo | ParaView | 6 | July 18, 2006 13:22 |
CFX -5.7.1 Intermittent Licensing Problems | James Date | CFX | 4 | February 14, 2005 06:22 |
