laplacianFoam, floating point exception
Old   December 19, 2014, 16:32
Default laplacianFoam, floating point exception
Max Kern
blueteeth is on a distinguished road
I'm a new OpenFoam user and stuck with a problem you might consider rather trivial.
I tried to run a simulation very similar to the laplacianFoam (flange) tutorial.
controlDict, fvSchemes, transportProperties and fvSolution are the same as in the tutorial.
The Mesh was generated with blockMesh
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.001;
vertices
 (-5 -5 0) //0
 (5 -5 0) //1
 (5 5 0) //2
 (-5 5 0) //3
 (-5 -5 50) //4
 (5 -5 50) //5
 (5 5 50) //6
 (-5 5 50) //7
blocks
 hex (0 1 5 4 3 2 6 7) (10 100 10) simpleGrading (1 1 1) //0
edges
patches
 patch front
 (0 1 2 3)
 patch back
 (4 5 6 7)
 patch tube
 (0 3 7 4)
 (3 2 6 7)
 (1 5 6 2)
 (0 1 5 4)
Boundary Conditions:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      T;
dimensions      [ 0 0 0 1 0 0 0 ];
internalField   uniform 273;
boundaryField
    front
        type            fixedValue;
        value           uniform 273;
    tube
        type            zeroGradient;
    back
        type            fixedValue;
        value           uniform 573;
blockMesh runs fine but when I try to run laplacianFoam I end up with the following:
DICPCG:  Solving for T, Initial residual = 0.480419, Final residual = 8.34292e-07, No Iterations 60
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#5  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
#6  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
 at ??:?
 at ??:?
#9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
 at ??:?
Floating point exception (core dumped)
Where's my mistake?
Thanks,
Max
blueteeth is offline   Reply With Quote
floating point exception, laplacianfoam
Floating point exception with pimpleDyMFoam ebah6 OpenFOAM Running, Solving & CFD 9 November 1, 2017 05:58
Inlet Velocity Profile BC - Floating Point exception during solution initialization Janshi STAR-CCM+ 4 March 14, 2012 10:21
simpleFoam Floating point exception error -help sudhasran OpenFOAM Running, Solving & CFD 3 March 12, 2012 16:23
Pipe flow in settlingFoam floating point exception jochemvandenbosch OpenFOAM Running, Solving & CFD 4 February 16, 2012 03:24
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 04:59
