Problem with multicomponentmixture initialization
Old   December 17, 2014, 09:43
Default Problem with multicomponentmixture initialization
Vincent RIVOLA
vinz is on a distinguished road
Dear forumers,
I am currently trying to simulate the injection of different gases into air.
So far, I had no problem simulating the injection of gas1 at inlet1. No problem either when I try to inject gas2 at inlet2 of my problem.
I can also inject 50% of each gas at both inlets. So inlet1 is injecting 50% of gas1 and 50% of gas2. The same at inlet 2.
It is actually working fine for any proportion of gas1/gas2 EXCEPT 100% / 0% for one of the two gases. So I can't inject 100% gas1 at inlet1 and at the same time 100% of gas2 at inlet2.
For all these cases, I don't inject any air at the inlets (so fixedValue BC at 0.0 for specie air).
When I say that it does not work, it is that I get an fpe when the code is building the thermoPhysicalModel.
Even more strange, the behaviour is changing depending on the order of declaration of species in the thermophysicalDict file!
Here are some informations on the settings:
- thermophysicalProperties:
thermoType
    type            hePsiThermo;
    mixture         multiComponentMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
species
    air
    gas1
    gas2
inertSpecie air;
air
    specie
        nMoles      1;
        molWeight   28.97;
    thermodynamics
        Cp          1005;
        Hf          0;
    transport
        mu          1.78e-05;
        Pr          0.7;
gas1
    specie
        nMoles      1;
        molWeight   29.56;
    thermodynamics
        Cp          2445;
        Hf          0;
    transport
        mu          9e-05;
        Pr          0.7;
gas2
    specie
        nMoles      1;
        molWeight   16.55;
    thermodynamics
        Cp          2894.53;
        Hf          0;
    transport
        mu          9e-05;
        Pr          0.7;
- gas1
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0.0;
boundaryField
    "inlet1"
        type            fixedValue;
        value           uniform 1.0;
    "inlet2"
        type            fixedValue;
        value           uniform 0.0;
- gas2
boundaryField
    "inlet1"
        type            fixedValue;
        value           uniform 0.0;
    "inlet2"
        type            fixedValue;
        value           uniform 1.0;
- air
internalField   uniform 1.0;
boundaryField
    "inlet1"
        type            fixedValue;
        value           uniform 0.0;
    "inlet2"
        type            fixedValue;
        value           uniform 0.0;
- Crash
Reading thermophysical properties
Selecting thermodynamics package
    type            hePsiThermo;
    transport       const;
    thermo          hConst;
    specie          specie;
#0  Foam::error::printStack(Foam::Ostream&) in "/CFDBB/vincent/OpenFOAM//OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/CFDBB/vincent/OpenFOAM//OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::multiComponentMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > >::patchFaceMixture(int, int) const in "/CFDBB/vincent/OpenFOAM//OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so"
#4  Foam::heThermo<Foam::psiReactionThermo, Foam::SpecieMixture<Foam::multiComponentMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > > >::he(Foam::Field<double> const&, Foam::Field<double> const&, int) const in "/CFDBB/vincent/OpenFOAM//OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so"
#5  Foam::heThermo<Foam::psiReactionThermo, Foam::SpecieMixture<Foam::multiComponentMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > > >::init() in "/CFDBB/vincent/OpenFOAM//OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so"
#6  Foam::heThermo<Foam::psiReactionThermo, Foam::SpecieMixture<Foam::multiComponentMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > > >::heThermo(Foam::fvMesh const&, Foam::word const&) in "/CFDBB/vincent/OpenFOAM//OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so"
#7  Foam::psiReactionThermo::addfvMeshConstructorToTable<Foam::hePsiThermo<Foam::psiReactionThermo, Foam::SpecieMixture<Foam::multiComponentMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > > > >::New(Foam::fvMesh const&, Foam::word const&) in "/CFDBB/vincent/OpenFOAM//OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so"
#8  Foam::autoPtr<Foam::psiReactionThermo> Foam::basicThermo::New<Foam::psiReactionThermo>(Foam::fvMesh const&, Foam::word const&) in "/CFDBB/vincent/OpenFOAM//OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so"
#9  Foam::psiReactionThermo::New(Foam::fvMesh const&, Foam::word const&) in "/CFDBB/vincent/OpenFOAM//OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so"
I guess that the problem is really coming from some 0 value at one of the boundary conditions but I don't see any reason why.
Does someone has an idea on what's going on?
vinz is offline   Reply With Quote
Old   January 6, 2015, 08:45
Yu-sen Niu
shenzhou1987 is on a distinguished road
Hi, I have meet the similar problem. Can U email me your case, so that I can learn how to deal with boundary condition and initial conditon. In addition, my case includes 4 cellZones, and I want to patch different values for different cellZone as initial condition. Can U tell me how to do this?
Thank U very much!
shenzhou1987 is offline   Reply With Quote
initialization problem in fluent morteza08 Main CFD Forum 0 January 17, 2011 12:04
Initialization problem when using Axisymmetry BC Eduardo FLUENT 0 August 4, 2008 09:23
coal combustion initialization problem Chetan Prahsant CFX 1 May 1, 2007 05:41
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
