External vehicle aero - cd and cl oscillations (simpleFoam) |
January 6, 2015, 09:04 |
Petr Furmanek
Rep Power: 14 |
Nice afternoon to all!
what is your experience with cl and cd behaviour during steady (simpleFoam) simulation of external vehicle aerodynamics? The problem I face is that all the residuals are converged (almost don't change in time for many iterations) but cl and cd coefficients oscillate. And quite a lot - cl in <0.11. 0.195> and cd in <0.305, 0.355> (details in the attached pictures). I would expect some oscillations with k-omega SST model I use, but in 3rd or 4th decimal place, not in 2nd... I'm using snappyHexMesh with 10 prism layers on the car body and wheels, 8 on the chassis and 5 on mudguards with the following checkMesh output Code:
Overall domain bounding box (-20 -18 -0.2616) (60 1.03886e-32 17.7384) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-3.26662e-16 -4.62421e-16 -8.6276e-14) OK. Max cell openness = 4.55546e-15 OK. Max aspect ratio = 257.513 OK. Minimum face area = 5.435e-10. Maximum face area = 0.453756. Face area magnitudes OK. Min volume = 2.4974e-11. Max volume = 0.302519. Total volume = 25916.9. Cell volumes OK. Mesh non-orthogonality Max: 83.8692 average: 7.62046 *Number of severely non-orthogonal (> 70 degrees) faces: 695. Non-orthogonality check OK. <<Writing 695 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. ***Max skewness = 7.92292, 99 highly skew faces detected which may impair the quality of the results <<Writing 99 skew faces to set skewFaces Coupled point location match (average 0) OK. Code:
ddtSchemes { default steadyState; } gradSchemes { default cellLimited leastSquares 1.0; grad(U) cellLimited leastSquares 1.0; } divSchemes { default none; div(phi,U) bounded Gauss linearUpwindV grad(U); div(phi,k) bounded Gauss upwind; div(phi,omega) bounded Gauss upwind; div((nuEff*dev(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear limited 0.5; } interpolationSchemes { default linear; } snGradSchemes { default limited 0.5; } fluxRequired { default no; p; } Code:
solvers { p { solver GAMG; tolerance 1e-7; relTol 1e-3; // def. 1e-2 smoother DICGaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration on; agglomerator faceAreaPair; nCellsInCoarsestLevel 10; mergeLevels 1; minIter 2; maxIter 50; } "(U|k|omega).*" { solver smoothSolver; smoother DILUGaussSeidel; tolerance 1e-8; relTol 0;//0.01;// def. 0.1; nSweeps 2; } } SIMPLE { nNonOrthogonalCorrectors 0; residualControl { p 1e-3; U 1e-3; "(k|omega)" 1e-4; } } potentialFlow { nNonOrthogonalCorrectors 20; } relaxationFactors { fields { p 0.15; } equations { U 0.5; k 0.5; omega 0.5; } } cache { grad(U); } |
