January 19, 2015, 10:02 |
BC for turbulent internal flow
Hoarau Yannick
Rep Power: 17 |
Hi
I want to compute the turbulent around a cylinder array inside a channel. I've a fine structured grid but I'm not able to find the proper combination of inlet/outlet to solve this : I always end up with diverging time step continuity errors. I tried many combination : - fixed inlet and Neumann outlet for U, Neumann Inlet and fixed outlet for P - massflow inlet and Neumann outlet for U, Neumann Inlet and fixed outlet for P - fixed inlet and Neumann outlet for U, Neumann Inlet and outlet for P - fixed inlet and massflow outlet for U, Neumann Inlet and fixed outlet for P Nothing is working. If anyone has an idea, I take it. Many thanks Yannick |
January 19, 2015, 10:09 |
anonymous
Rep Power: 12 |
Reynolds Number? Relaxation Factors? Solver used? Transient, steady? Discretization Schemes? Mesh foto?
How far away is your inlet and outlet from the domain of interest? We need more information about it to solve the problem. If you are you using a transient problem, are you using pimpleFoam? It will let you control the maxCourant number so that your simulation doesn´t blow because of the Courant, although it may blow for other reasons. |
January 19, 2015, 12:11 |
Hoarau Yannick
Rep Power: 17 |
Hi
The configuration and the grids are described in this paper : http://www.sciencedirect.com/science...89974614000358 I used here SA with pimpleFoam. Here is the fvscheme : ddtSchemes { default Euler; } gradSchemes { default Gauss linear; grad(nuTilda) cellLimited Gauss linear 1; grad(k) cellLimited Gauss linear 1; grad(kl) cellLimited Gauss linear 1; grad(omega) cellLimited Gauss linear 1; grad(epsilon) cellLimited Gauss linear 1; grad(q) cellLimited Gauss linear 1; grad(zeta) cellLimited Gauss linear 1; grad(v2) cellLimited Gauss linear 1; grad(f) cellLimited Gauss linear 1; grad(sqrt(kt)) cellLimited Gauss linear 1; grad(kt) cellLimited Gauss linear 1; grad(sqrt(kl)) cellLimited Gauss linear 1; } divSchemes { default Gauss linear; div(phi,U) bounded Gauss linearUpwindV grad(U); div(phi,k) bounded Gauss linearUpwind grad(k); div(phi,epsilon) bounded Gauss linearUpwind grad(epsilon); div(phi,zeta) bounded Gauss linearUpwind grad(zeta); div(phi,q) bounded Gauss linearUpwind grad(q); div(phi,omega) bounded Gauss linearUpwind grad(omega); div(phi,nuTilda) bounded Gauss linearUpwind grad(nuTilda); div(phi,T) bounded Gauss limitedLinear 1; div(phi,kl) Gauss limitedLinear 1; div(phi,kt) Gauss limitedLinear 1; div(phi,R) Gauss upwind; div(R) Gauss linear; div((nuEff*dev(grad(U).T()))) Gauss linear; div(phi,v2) bounded Gauss linearUpwind grad(v2); div(phi,f) bounded Gauss linearUpwind grad(f); } interpolationSchemes { default linear; interpolate(HbyA) linear; } laplacianSchemes { default Gauss linear limited 0.333; } snGradSchemes { default limited 0.333; } fluxRequired { default no; p ; } |
January 22, 2015, 08:02 |
Cedric DUPRAT
Rep Power: 17 |
Yannick,
I guess not everyone have access to sciencedirect papers (indeed, I don't). However, I did some simple turbulent flow calculation around one cylinder without any problem using the following BC for Inlet and Outlet: for U: inlet { type fixedValue; value uniform (toto 0 0); } outlet { type inletOutlet; inletValue uniform (toto 0 0); value $internalField; } for p: inlet { type zeroGradient; } outlet { type zeroGradient; } I hope this will help you, Regards, Cedric |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Question Regarding Modelling Internal Flow | Alteran | CFX | 1 | September 4, 2013 12:07 |
Internal Flow with Heat Transfer | plucas | OpenFOAM | 2 | January 18, 2013 11:47 |
Advice on turbulence model for complex internal flow | JPBodner | Main CFD Forum | 1 | September 3, 2011 03:07 |
Why Re is diff for external and internal flow? | john | Main CFD Forum | 1 | June 13, 2007 02:58 |
